04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Putting rods in
Old Jul 17, 2009 | 09:01 AM
RalliartPro's Avatar
Putting rods in
I'm going turbo so I'm doing all the internals. Can I put new rods in with the same bearings I have? the bearings are a few months old and I haven't abused my car at all.
Old Jul 17, 2009 | 09:32 AM
Cj98's Avatar
If your going to redo it why have old bearings with new rods, you can always set aside those bearings or try to sell them.
Old Jul 17, 2009 | 09:34 AM
evoix16's Avatar
Put new ones in so no worries later
Old Jul 17, 2009 | 09:40 AM
Ralliart_on_LSD's Avatar
do it right the first time so you dont blow it up and do it all over again next year...
i should take my own advice tho
Old Jul 17, 2009 | 09:55 AM
hackish's Avatar
Bearings are cheap cheap cheap, you'd be crazy not to replace them and I can't think of anyone who would buy a used set of bearings. Don't bother doing the mains, just the rod bearings. The weak point on these engines is really the pistons so make sure you get pistons and rods.
-Michael
Old Jul 17, 2009 | 12:37 PM
okay so if I can put evo rods and I know I ask this question here before, why can't evo rod bearings be used?
Old Jul 17, 2009 | 01:27 PM
hackish's Avatar
If the EVO rods fit then I can't see why a new set of bearings for that application wouldn't also fit. The whole point is get new bearings and make sure they're sized properly.
-Michael
Old Jul 17, 2009 | 09:23 PM
okay I'll change my bearings, I was just being cheap. If anyone knows for certain if evo bearings work, I guess I'll get the cosworth bearings.
Old Jul 18, 2009 | 08:44 AM
i notice in your sig you have a STM balance shaft eliminator kit... do you have a link for it? and what did it do for the motor, performance and revvability wise (if thats a word? lol)
Old Jul 19, 2009 | 07:38 AM
just want to bump, interested in this BS eliminator kit. thanks
Old Jul 22, 2009 | 10:58 AM
bump bump bump. about ready to order my BS kit, but i wanted to know how this one works compared tot he AMS one. most likely getting the AMS one cuz they are hands down best company for evo's and mitsu parts. But just curious how this one worked out for you.
Old Jul 23, 2009 | 11:16 AM
mybad I forgot about the thread. well I felt more torque and very noticable on throttle response and the rpm drops much quicker and the balance shafts were pretty heavy probably six pounds each. The ams one is of course the best and is more safer on the bearings. I just did away with the balance shafts because I rebuild my motor all the time and was also being cheap at the time I did it. I would get the ams it looks alot more solid proof than actually eliminating them.
Old Aug 3, 2009 | 05:42 AM
migueralliart's Avatar
I wouldn't remove them if I were you, the 4G69 vibrates a lot from the factory, removing these BS is just making these vibration worse, they are there to make your life a better, since you are building your engine , the HP gain from removing the BS is minimal and the cons are more.
Old Aug 7, 2009 | 11:41 AM
My engine doesn't vibrate at all even under full throttle.
Old Aug 7, 2009 | 01:16 PM
between the motor mounts, and the eliminator, i would think your motor vibrates alot. Mine sure did, pre-BS Eliminator.
either or. I'm not worried about minor stuff like vibration and all. I have a jetta for a daily driver. this car will only see the road once a weeek during the summer, and probably towed to the track, incase it blows there. It will put on 500 miles a year, if that. Its dedicated race car. I'm just worried about it making my motor blow up. and this is the safest eliminator in the market, so i think i'll be ok, with a mild 550whp in the future.
thanks alot for the info and input tho
