04-06 Ralliart Engine/Drivetrain (no forced induction)
sr intake question
Old Dec 13, 2004 | 06:42 PM
lucky04's Avatar
sr intake question
ok my dad bought a cai for his hemi but he didnt like it so i took the upper half of it and drilled an inch and a quarter hole for the mas i put it one but didnt have a filter for it but just thought id take it around the block, so i pull out of the driveway and start going, i goto shift and the car dies is that because i have no filter on it or do you guys think its something else.
my theory(prolly wrong) but i think its sucking to much air and its trying to dump a bunch of fuel and it floods it out. or something along those lines.
Old Dec 13, 2004 | 06:46 PM
ralliart86's Avatar
i seriously have no idea... you could be right... i would sugguest putting the stock air filter back and if it still has problems maybe reset the ecu... im no expert though
Old Dec 13, 2004 | 06:53 PM
lucky04's Avatar
well i put it back on (stock airbox)and have no problems now. i just wnat to get some input before i go buy a filter and waste the money
Old Dec 13, 2004 | 06:55 PM
AdamRA's Avatar
How did you attach the MAS to the pipe?
Never drive a car without a filter.
Old Dec 13, 2004 | 07:04 PM
wrecked's Avatar
That is my question too. If it was not a air tight fit, the air passing through it, and missing the sensor will send the wrong signals it the ECU.
Old Dec 13, 2004 | 07:05 PM
lucky04's Avatar
i didnt attach it. it fit inside the really snugg. Guys understand that this was just a trial thing just seing if it would work nothing has been set in stone yet
Old Dec 14, 2004 | 02:31 PM
1ChikDrivesStik's Avatar
This thread makes me want to cry. Why do people do these sort of things to their cars?!
Old Dec 14, 2004 | 07:05 PM
bruce988jl's Avatar
Well i think it was because of the fact that you had no filter... And instead of the car having to work at sucking air in there was no resistance <normally created by the air filter> and thus it sucked so much air in that it make the car run so lean that it died... Similar effect to a car running too rich with too much gas and not enough air... But that's my guess.. so don't take my word for it... I'm probably wrong
-Lee
Old Dec 15, 2004 | 04:02 PM
BLKRalliArt04's Avatar
when you refer to the "hemi" engine in the dodge's, what particular engine are you talking about?
Old Dec 15, 2004 | 06:32 PM
lucky04's Avatar
2003 dodge 2500 with a hemi 360ci the new one not an old one
Old Dec 16, 2004 | 04:43 AM
Canadian Canuck's Avatar
everytime you mess with your car and f*** it up.........a puppy dies.
Old Dec 16, 2004 | 08:32 AM
turbonutter's Avatar
Actually (yes I'm nit-picking here) the engine is 347ci not 360. The 360 is the last generation non-hemi V8.
Old Dec 16, 2004 | 06:46 PM
lucky04's Avatar
oh sry im not really into those things all i know about that truck is its a gas hog 10.6 mpg but ok id like to get on topic here
Old Dec 16, 2004 | 10:12 PM
otter's Avatar
EvoM Administrator
I would recommend welding the hole you made shut, sell the intake on eBay, then use that money to buy a SRI that's actually made for your car.
Old Dec 17, 2004 | 05:04 AM
ModernRacer's Avatar
Could be due to, too much air,causing the engine to bog down and die, i've seen this before
