04-06 Ralliart Engine/Drivetrain (no forced induction)
Piggyback Pros and Cons
Old Dec 2, 2005 | 07:26 PM
Larr_E's Avatar
I've wanted to get one but a friend of mine told me I wouldn't pass a smog in cali. Is this true? What are the Pros and Cons of it as a whole...
Old Dec 2, 2005 | 08:08 PM
otter's Avatar
EvoM Administrator
You'll still pass smog. You won't have a CEL, and your emissions should actually be a touch cleaner due to burning less fuel.
Pros:
More power and a more smooth powerband
Engine doesn't run as rich (cleaner emissions?)
Better throttle response
Better gas milage
Cons:
More expensive gas
Have to splice into some wires going into your ECU
That's about it.
Old Dec 3, 2005 | 12:23 AM
justinhazard's Avatar
Con #3: More tickets... Sorry but its a fact!
Old Dec 3, 2005 | 04:56 AM
matute's Avatar
Actually i believe that the amounth of tickets you recieve is directly proportional with the weight of your right foot. So you should not blame it in the PB.
Old Dec 3, 2005 | 04:58 AM
Well considering all my food is stored in my right foot... Thats my excuse next time I get pulled over
Old Dec 3, 2005 | 05:00 AM
matute's Avatar
Good luck!!! you'll need it
Old Dec 3, 2005 | 05:02 AM
Oh and just for your info, no I don't sit on here all night waiting for replies, I just happened to look at it.
Old Dec 3, 2005 | 06:40 AM
morpheus256's Avatar
suuuure justin, we all know your a post *****
Old Dec 4, 2005 | 01:50 PM
Wow Morpheus you posted!! I better take a picture
Old Dec 4, 2005 | 02:34 PM
Ryan_VRX06's Avatar
Lead accumulation in the bloodstream that gets deposited in the right foot.
Seriously though, how hard is it to install one of these? Never having done any real auto-electrical kinda stuff (changing bulbs and fuses is about the extent of my experience there)
is it fairly straight forward? And would I be likely at all to really screw things up trying to install it?
Oh and in the event of something going wrong with the car after installing - is it easy to remove so the dealer won't raise eyebrows and set fire to my warranty?
Old Dec 4, 2005 | 04:20 PM
chowetime's Avatar
Hey Ryan your best person to talk to will be RPW as he has wired in heaps of the GReddy units into cars he has the experience and has it down to a fine art form these days so you won't be spending days waiting for someone to wire it up you will also need to have it tuned which he uses Speedworks to do as they have the most experience in doing it... voiding warranty ??? I don't know I mean yes it changes the way the car works - more effiecently.... but I really don't care too much for warranties they are only as good as the paper they are written on and how they are interperated
Old Dec 4, 2005 | 06:54 PM
Ryan_VRX06's Avatar
Good point that
Sounds very cool, I'd say you are right and thats the best way to go- he sell the computers too? Or do you need to order them from RRM or whoever?
Thursday night and I'll be home to drive something that isnt a white toyota 4x4 yay!!
Old Dec 4, 2005 | 11:18 PM
chowetime's Avatar
David has the Greddy in stock all the time as well as all the other harnessess that are needed as well as what ever programs to kick start it... my thoughts are for you to either swing by his work shop and say hi... he will give you all the info that you will need and show you all the options for you if you are wanting to keep the warranty in tact
Old Dec 5, 2005 | 11:20 AM
KillahB's Avatar
Everyone likes the RRM piggybacks. I havent worked with them but it seems they make people happy. I prefer a variable piggyback that you can adjust with your mods however, like an Emanage or my "poor man's Emanage" the SAFC / SITC combo. Your choice tho.
Old Dec 17, 2005 | 10:18 PM
Myszkewicz's Avatar
I installed mine today in about 10 minutes. The only way I could see someone screwing it up was if they weren't careful about WHICH black/yellow wire they were tapping into in the #2 connector for power. In one corner is the wire you want, a black/yellow wire that supplies battery power to the ECU. In the opposite corner is another black/yellow wire, which goes to the #2 ignition coil. Just check the wire for a constant +12v before tapping into it.
The way I wired mine in, I could unplug it and remove the unit and have the wiring back to stock function in about 1 minute. The only signs that it was ever there would be a male/female spade connector pair on the airflow wire, and three shielded male spade connector pigtails hanging for the other three wires. You'd really have to be looking for them to see them.
My only question for RRM is about power draw. The red wire from the Piggyback is connected to a constant source of power, and the ground wire used is always grounded, which means this thing is always on. How much power does it draw? I know I shouldn't worry about it if I drive the car every day, but is this something I should disconnect if I go on vacation for a week?
Hmm.. I suppose I could go out and hook up my ammeter in line with the unit to check the draw...
