RRM UD Pulley
RRM UD Pulley
I was thinking about installing the RRM UD pulley but i know that some pullies eliminate the A/C in your car, i was wondering can u still run A/C with the pulley
Thnx Muck
Thnx Muck
Originally Posted by ralliart329
now if our ac isnt on is it still on the belt? i know my dads kia the A/C would only run on the belt if it was on, and i think the defogger was the same pulley..
i have the pulley and know it works the same. but my dads kia sedona the pulley or w/e for the AC actually lifted off the belt when not in use. found that out when the pulley locked b/c it wasnt in use but didnt lift off the belt and then tore through the belt. does our car run the pulley for the AC even when we dont have it on?
The only thing is that it is supossed to rob some voltage from the alternator due to the fact that it is now running at a slower speed. But that is BS cuz I had mine since mile 13,000 and its still coming strong now at 45,800 miles, no problems whatsoever, voltage running strong. If you have your doubts still, just get a grounding kit to give voltage more continuity.
And that nice accel the first 3 gears is totally feelable from the get go. Just get enough traction, if you chirp second for too long its a little slower to built back up due to the fct that it take about 3 punds of torque to give you 8 whp dyno proven by me
Did that clear it up for you?
