SS Clutch Lines - Cheap Cheap Cheap
I found this on Ebay:
http://cgi.ebay.com/Stainless-Clutch...QQcmdZViewItem
$35.00 USD Shipped for a Stanless Steel Braided Clutch Line....I just bought one as this is less than HALF of what RRM would charge to send one for me to Canada.
It didn't really say if it was compatible with a RA, so after a quick search, I found another retailer using the same part for a number of cars, which told me that the Ebay part SHOULD fit.
Check this link as a refrence:
http://www.sportcompactonly.com/perf...aspx?c=72&b=53
Hope you guys find this helpfull.
The Ebay seller also has SS Brake line kits....but the listing says the application is for 2002-2003 Lancer w/drums.
Would the brake link kit work with an RA with rear discs as well ?
http://cgi.ebay.com/Stainless-Steel-...QQcmdZViewItem
Check out the link and let me know.
Thanks again.
Allan
Allan
Thanks again.
Allan
Allan
Well, after using the same 3rd part site as a refrence.....
http://www.sportcompactonly.com/perf...rts.aspx?c=133
It seems as though the same kits are used for multiple cars as well on the above site.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200040971130
...I bought the brake lines the Ebay seller had as well.
Just over $100 USD including Shipping for new brake lines and a new clutch line.....definately a savings over other vendors me thinks
That's not the same clutch line as what RRM sells. Also, I hope what's in the picture isn't what they're sending you, as neither of the two clutch lines in the Ralliart have ends like that.
Upper clutch line (rubber part) can be found cheaply anywhere, just look for the Evo clutchline. The WORKS one cost me about $20 locally. The lower clutchline, that RRM sells, is the one that eliminates the restrictor, and ONLY RRM sells that.
The WORKS clutchline has a few elements that are better in design than the standard clutchlines available locally. One big design difference being the angled part where it bolts to the master cylinder. This helps installation A LOT.
