Re-Flash...Unanswered
That'd be a lot of wiring to redo, too, and I don't think that ECU is capable of controlling the 4G69's MIVEC (different from the 4G63 MIVEC)
You're probably right...
Here's the Ralliart pinout :
TERMINAL NO. ITEM (Ralliart)
1 Orange - No.1 injector
3 Blue/yellow - EGR valve (stepper motor coil <A1>)
5 White/red - No.2 injector
7 Malfunction indicator lamp (SERVICE ENGINE SOON or check engine lamp)
8 Fuel pump relay
10 Blue/red - Heated oxygen sensor heater (front)
11 Yellow/black - Evaporative emission ventilation solenoid
12 Yellow - EGR valve (stepper motor coil <A2>)
13 "CRUISE" indicator light input
14 Green - No.3 injector
15 Blue - Throttle actuator control motor relay
16 A/C compressor clutch relay
17 Blue/black - Fan control module
18 Blue/yellow - Heated oxygen sensor heater (rear)
19 White/blue - EGR valve (stepper motor coil <B1>)
21 Red - No.4 injector
23 Yellow/green - Evaporative emission purge solenoid
26 Green/orange - EGR valve (stepper motor coil <B2>)
27 Gray - Engine oil pressure switch
31 Black/yellow - Ignition coil - No. 1 (Ignition power transistor)
32 Black/green - Ignition coil - No. 2 (Ignition power transistor)
33 Ground
34 Red/yellow - Power supply
35 Red/black - Ignition coil - No. 3 (Ignition power transistor)
38 Accelerator pedal position switch
39 Green - Brake light switch
40 Clutch pedal position switch <M/T>
42 Ground
43 Red/yellow - Power supply
45 Blue/white - Generator G terminal
47 Red/white - Power steering pressure switch
50 Ignition switch-IG
51 Ignition switch-ST
52 Brown/green - Ignition coil - No. 4 (Ignition power transistor)
54 Blue - Cruise control cancel switch on brake pedal
57 Red - MFI relay (power supply)
58 Black/yellow - Backup power supply
63 White/red - Mass airflow sensor
69 A/C switch
70 Brown/green - Crankshaft position sensor
71 Blue/red - Camshaft position sensor
72 White/black - Fuel level sensor
74 Diagnostic output
78 A/C switch 2
79 Black/yellow - Vehicle speed sensor <M/T>
81 Light green/white - Fuel tank temperature sensor
82 Fuel tank differential pressure sensor
86 White - Generator FR terminal
87 Green/white - Tachometer signal
88 Black - Ground
89 White - Knock sensor
91 Brown/white - Ground
92 Blue/white - Power supply voltage applied to accelerator pedal position sensor (main)
94 Cruise control switch power supply
95 Pink/black - Engine oil control valve
96 Black - Ground
97 Yellow/red - Sensor supplied voltage
98 Yellow/white - Engine coolant temperature sensor
99 Yellow/blue - Intake air temperature sensor
101 Light green/white - Manifold absolute pressure sensor
105 Black - Throttle position sensor ground
106 Red - Power supply voltage applied to throttle position sensor
107 Blue - Accelerator pedal position sensor (sub)
108 White - Heated oxygen sensor (front)
113 Green - Throttle position sensor (sub)
114 Gray - Accelerator pedal position sensor (main)
115 White - Throttle position sensor (main)
116 White - Heated oxygen sensor (rear)
132 Red/white - Power supply voltage applied to throttle actuator control motor
133 Blue/red - Throttle actuator control motor (+)
141 Blue/yellow - Throttle actuator control motor (-)
and here's EVO8, OZ one
Evo VIII ECU Pinouts
1 #1 Injector
2 #3 Injector
3 Fuel Pressure solenoid
4 Idle Speed Control Motor Coil A1
5 Idle Speed Control Motor Coil B1
6 EGR Solenoid
8 A/C
9 Evap Emissions Purge Solenoid
10 Ignition Power Transistor (A- to coil for 1&4 cyl)
11 Wastegate solenoid
12 12V switched power supply
13 Chassis ground
14 #2 Injector
15 #4 Injector
16
17 Idle Speed Control Motor Coil A2
18 Idle Speed Control Motor Coil B2
19 MAS sensor reset signal
20
21 Cooling Fan Motor Relay (PWM Output)
22 Fuel pump relay
23 Ignition power transistor (B - to coil for 2&3 cyl)
24 A/C
25 12V switched power supply
26 Chassis ground
31 A/C
32 A/C
33 Generator G terminal
34
35 FMIC sprayer
36 CEL
37 Power Steering pressure switch (input)
38 MFI Relay
39 Fuel Pump Relay (increase pressure for higher loads)
40 Sensor Ground (IAT, Cam and Crank Angle Sensors)
41 Generator FR terminal
42
43 Clutch Position Switch (Input)
44 FMIC sprayer
45 A/C Switch
46 Fuel level (input)
51 Immobilizer ECU
52
53
54 O2 sensor heater (rear)
55 Evap vent solenoid valve
56
57 FMIC sprayer
58 Tach signal (output)
59
60 O2 sensor heater (front)
61 Fuel Tank Differential Pressure Sensor
62 Data Link Connector
71 Starter (signal)
72 IAT sensor (signal)
73 Manifold differential presssure sensor
74 Sub fuel level sensor
75 O2 sensor (rear)
76 O2 sensor (front)
77 Fuel temperature sensor
78 Knock sensor
79 Data link connector
80 Backup power (12V constant)
81 5V Sensor Power Supply (TPS, MDP, Baro, Fuel Tank Press Sensor)
82 Ignition
83 Coolant temp sensor (signal)
84 TPS sensor (signal)
85 Barometric pressure sensor (signal)
86 Vehicle speed sensor (signal)
87
88 Cam position sensor (signal)
89 Crank position sensor (signal)
90 MAS sensor (signal)
91 FMIC sprayer
92 Sensor Ground (O2 Sensors, Coolant Temp, TPS, MDP, Fuel Tank Press Sensor)
And Ralliart's ECU use 5 connectors while other ECU use 4 connectors
8 Fuel pump relay
33 Ground
42 Ground
69 A/C switch
78 A/C switch 2
88 Black - Ground
96 Black - Ground
1 #1 Injector
2 #3 Injector
6 EGR Solenoid
8 A/C
13 Chassis ground
14 #2 Injector
15 #4 Injector
16
20
22 Fuel pump relay
24 A/C
26 Chassis ground
31 A/C
32 A/C
34
35 FMIC sprayer
36 CEL
38 MFI Relay
42
44 FMIC sprayer
45 A/C Switch
51 Immobilizer ECU
52
53
56
57 FMIC sprayer
59
71 Starter (signal)
75 O2 sensor (rear)
78 Knock sensor
82 Ignition
87
91 FMIC sprayer
So OpenECU hasn't hacked the Ralliart ecu yet? Bummer... I'm looking forward to a swap in the next year...hopefully we could get them to take a look at it. I would guess getting around the variable timing would be a little more difficult...but think how sweet it would be to tune that as well! Is the 4G94 supported by them? If so I could start screwing around with stuff on the dyno here at school.
I will be experimenting shortly with this, but just a gut feeling is the IX ECU will be the closest as it has dual MIVEC maps and only utilises one of them. I had often just assumed the second MIVEC map was for the V6's but now I am wondering if its not part of the 4G69 control as well. The thing you have to remember about any auto manufacturer (even high end ones) is they always gravitate to the lowest common denominator. They will never spend more money than they have to on a car because it means less profit. The same chip can be used in 4 different makes of car, the software can be completely interchangeable between certain years (LS1 small blocks and Duramaxes share the same chip and software for instance) and models.
MJ-I kind of think that if anyone had been successful they would have sold/traded the information as soon as they had a buyer. The fact that no one has come forth tends to lead to the Occham's Razor of tuning.
Although I tend to agree with you about that..
my conspiracy theory brain thinks that if it was extracted, the person extracting it would need a proper definition. So my consipiracy theory is that it was extracted and their figuring it out for their own profit. LOL
Yeah, we have a few more wires than them. Forgot about the extra stuff for the remote throttle control, too.
