Now i'm confused about what engine we have
So i went to a prts place online they say we have a 4g64. I thought we have a 4g69.
check it out..Just reassure me..thanks
http://www.usedpartslive.com/catalog...t=lancer&cat=h
I've found that to be the case with many automotive stores. They instantly assume that since it's a 2.4L Lancer, it must be the 4G64.... 'cause Mitsu isn't capable of making new engines. I think NAPA lists it as the 64, too.
what do you mean by Mitsubishi is not capable or making new engines ?
Sarcasm.
Yes, the 4G63 is 2.0 and the 4G64 and 4G69 are 2.4. Here's how Mitsu's engine codes work, using 4G63 as the example:
4 - cylinders
G - Iron block, gasoline (I'm assuming, in the new engines, B - gasoline aluminum block or something like that)
6 - engine series.
3 - engine model
Basically, all 4G6* engines start off with the same block, then it's modified to the specific engine model.
4 - cylinders
6 - engine series.
3 - engine model
Sarcasm.
4 - cylinders
6 - engine series.
3 - engine model
4 - cylinders
6 - engine series.
3 - engine model
so what does an evo have and does a rallyart / lancer have?
EVO 4G63 ?
i would be happy if you guys point me somewhere I can read about mitsubishi engines...
I mean if the lancer and rallyart and evo engine is a 4G63, then what makes them different? a turbo slapped onto the evo?
Im trying to learn so please dont flame me..
