04-06 Ralliart Engine/Drivetrain (no forced induction)
the rrm udp
Old Dec 28, 2006 | 11:40 PM
hellview's Avatar
the rrm udp
i installed my udp about a week ago. and i noticeded today that theres kind of a squeeky sound coming from the engine, i think its coming from the belt area. also does anyone who has the udp notice that the engine shakes a bit more. the lower idling rps are normal im guessing.
Old Dec 29, 2006 | 12:05 AM
otter's Avatar
EvoM Administrator
Squeaky sounds?
Old Dec 29, 2006 | 12:20 AM
hellview's Avatar
almost like somthing is tapping somthing.
Old Dec 29, 2006 | 12:35 AM
otter's Avatar
EvoM Administrator
How loud?
Old Dec 29, 2006 | 05:56 AM
MitsuJoe's Avatar
There will be more belt noise with the use of this pulley. Although I am unsure of the squeak you are talking about...you have a mouse stuck under there?!? j/k
Old Dec 29, 2006 | 01:02 PM
amg_dragon's Avatar
I'm not doubting your mechanical skills but double check your torque numbers on the pulley. Make sure everything is nice and even.
Old Dec 30, 2006 | 08:32 AM
cokeandrum01's Avatar
....check the belt for rubbing as well. If the belt is rubbing you will smell burnt rubber often. If it's just the belt squeaking, throw on some belt dressing. I added some when I installed my UDP. I haven't heard any type of noises.
Old Dec 30, 2006 | 09:30 PM
egk-69's Avatar
what the torque supposed to have?
I installed mine and didnt measured the torque just do iut by hand
sory my english is bad and im a little drunk!, hehe
Old Dec 30, 2006 | 10:03 PM
otter's Avatar
EvoM Administrator
19 +- 2 ft/lbs. Being drunk is no excuse for bad typing.
Old Dec 30, 2006 | 10:45 PM
hellview's Avatar
i donno. my dad helped.. well he did most of it. it might just be the belt nois ur talking about
Old Jan 2, 2007 | 11:19 AM
hellview's Avatar
im confused on this tourqu nuimber stuff, i dont have a A in mechanics. everyone i asked said that its just a bolt on. its either on or off. ?? wat am i missing
Old Jan 3, 2007 | 10:45 AM
amg_dragon's Avatar
You have to properly (as in use a torque wrench set to 19 lbs) apply pressure to all the bolts to make sure they are:
1) ON
2) Not stripping the threads on the bolts
3) Making absolutely sure there isn't ANY chance of vibration coming from that specific part.
4) Peace of mind that you did your part in maintaining your car
5) Keeps people from making long obnoxious lists that list things you probably allready know (or should before attempting to work on your motor)
Old Feb 4, 2007 | 09:15 PM
wrecked's Avatar
I too had a squeeky belt from RRM. They would do nothing for me. I ended up buying a new belt with the same spec's.... squeek gone.
Old Feb 5, 2007 | 07:16 AM
otter's Avatar
EvoM Administrator
1) ON
More reasons why torquing bolts is needed. If you over-tighten a bolt, you risk stretching the bolt, stripping the threads out of the hole, and an all around bad time. Over-tightened bolts also risk breaking down the road and warping whatever they're bolted into, in this case, the UDP. Under-torquing bolts risks the bolts coming loose or backing out, obviously that's bad, too.
Pretty much every bolt on your car has a torque level assigned to it. Some aren't so important to get right, such as the torque to hold the plastic cover on the engine, others are so important that it's the different between a running and not-running engine, such as the head bolt torque.
Old Feb 5, 2007 | 09:18 AM
MitsuJoe's Avatar
How long did you have the belt?
