Done the mods now what ?
well i just did a SRI and a catback exhaust and I was wondering if once the mods are done do you need to reset the ECU to take full advantage of them ? im only asking because the civic i had before the Ralliart you had to reset the ECU after any mods to reset the maps
Yes.
This has been covered before. People reported that you should reset the ECU (via unplugging your battery connection) for 15 minutes, your car will then have to re-learn your driving profile and "adjust" by itself.
if you diconnect the negative put your on the brake that will drain what ever juice is left over, 15 minutes is a long time ,it will reset ,but your ecu is relearning all the time and will learn to add more fuel for these mods which are about 5-10 hp tops.so to take advantage for the first 1/2 hour yes reset other than that you will have to reset your radio and clock .do a search theres many threads on reseting your ecu.
