04-06 Ralliart Engine/Drivetrain (no forced induction)
Best Short Shifter, and brass Vs. Ploy Bushings
Old May 5, 2007 | 05:59 PM
vonzipper's Avatar
So i havent done any mods to my car in a while so, I have been looking into to making My car more enjoyable to drive. so i want to get a Short Shifter, shifter bushings (underhood and shifter base ones).RRM SS Clutch Line, Works Clutch Cable, and also engine Dampener.
I want to know who makes the best quality shifter, and which one has the shortest Reduction %
Also
Which kinda of shifter bushing should i get brass ones or the kartboy ploy bushings, i heard the brass bushing cause wear but a harder and stronger.
Can Anyone Help Me Out?
Old May 5, 2007 | 06:42 PM
superalf574's Avatar
umm the stock ra is a short shifter buying a aftermarket one wouldnt be that shorter than stock , also i have the kartboy had them for about 3 months installed feels more stiff and precise
Old May 5, 2007 | 06:52 PM
vonzipper's Avatar
the RPW, B&M, TWM, and Lancershop short shifter are shorter than stock.
Old May 5, 2007 | 06:55 PM
lanzerralliart's Avatar
EvoM Super Moderator
I have heard from peeps with the short shifter that it isn't to much of a difference, the bushings and the motor mounts would be more benificial IMO,and if you wanna make it shorter you can remove the black plastic spacer and drill out the knob about 5/8s of an inch and you can reduce the shifter an inch by doing this....
Old May 5, 2007 | 08:22 PM
reTro's Avatar
Herez my setup, and I love it:
Works 15% short shifter
Works counterweight shift knob (nice screw-on type, no crappy universal fit!)
Kartboy under base & under hood bushings
RRM clutch line
I like this setup, and it's deff shorter than stock. I'd prob go 30% though. I was affraid it would be too stiff, but I tried one vs mine, and it's not.
B&M setup looks nice too.
Old May 6, 2007 | 08:22 AM
otter's Avatar
EvoM Administrator
The brass bushings are the stiffest you can get. I've seen no excess wear on my car since putting them in 60,000 miles ago. Despite what the above people say, there IS a very noticable difference when you install a shortshifter. The stock "short" shifter that came with the car isn't very short at all.
I went with the budget setup when I did mine, and it's every bit as good as most of the other SS kits out there. Cost me around $130 total.
- Authority SS (about $50 + cost of new shift retainer)
- Speedsource brass bushings (underhood and shift base - $50 for them all)
- GReddy counterweight knob (about $20)
Old May 6, 2007 | 09:31 AM
vonzipper's Avatar
Ok so i think i have made my mind. i am going to go with
-works 30% short throw
-somekind of counterweight knob.
-speedsource brass bushings
-RRM SS clutch line
also Works sales a cluth cable, i remeber way back someone told me you could use both of them togather is that true. or are they just the same part.
Old May 6, 2007 | 09:52 AM
otter's Avatar
EvoM Administrator
Just gut your clutch restrictor and then get the works clutchline to remove the rubber section.
Old May 6, 2007 | 03:37 PM
my set up is
kartboy bushings under hood and shifter
greddy counterwieghted shift knob
stock shifter
Old May 7, 2007 | 05:24 AM
fkdrcrs's Avatar
RRM clutch line
how much of a difference does the clutchline make?
Old May 7, 2007 | 10:11 AM
reTro's Avatar
It's noticeable, but not dramatic. I guess it's one of those things that's more of a complementary mod when added to everything else.
Old May 8, 2007 | 09:30 PM
egk-69's Avatar
So I cant figure this out by my self
-what shortshifter fits my 2006 Ralliart?
-what shifter base bushing fits my car?
-what shifter cable bushing fits my car? (evos 5 speed, already know this)
AND PLEASE , were can I buy any of those things?
specially the short shifter!!!!!
any of this ones fits my car?:
http://cgi.ebay.com/ebaymotors/Mitsu...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/SHORT...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Short...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Racin...spagenameZWDVW
please help me
Here what I want!
-a short shifter that is not that expensive, but it's still good one (not more than $50-$80)
__________________
Old May 8, 2007 | 09:58 PM
egk-69's Avatar
does any EVO 5 speed short shifter fits my Lancer Ralliart??
does any Lancer 02-03 short shifter fits my Lancer Ralliart??
Old May 9, 2007 | 06:55 AM
otter's Avatar
EvoM Administrator
You should take a look at the noobie thread at the top of the general section. Yes, all Evo 5 speed SS will fit the car. Lancer ones should be identical, as well. Short shifters can be bought just about anywhere. Most vendors have them and they're all over eBay. The brass bushings can be bought from speedsource or an Evo vendor. Zaklee bushings can be bought in the Ralliart classifieds. Poly bushings can be bought from Kartboy.
Old May 9, 2007 | 10:55 PM
egk-69's Avatar
So those ones on the links I post, will FIT!!?
im sorry man, I think they fit, but every one here have short shifter, why not to ask people who actually have it?
thanks anyway
