04-06 Ralliart Engine/Drivetrain (no forced induction)
valve adjustment?
Old Aug 2, 2007 | 09:03 AM
bfield's Avatar
valve adjustment?
so my service engine light came on and as of lately when i turn on my a/c my car starts to idle really weird and sometimes will die..i talked to the service guy at the local mitsu place and he said that from what he thought it looked like it needed a valve adjustment. has anyone else experienced any of these symptoms?
Old Aug 2, 2007 | 01:27 PM
reTro's Avatar
Sounds like a vacuum leak to me. Usually any indling issue is a leak somewhere. Just check all your hoses and look for cracks or any that came off. There's a few hidden ones behind the intake manifold.
I can't imagine valves being so far out of adjustment they'd cause your car to stall.
Old Aug 2, 2007 | 02:11 PM
gjgfrombigd's Avatar
if it's a stuck valve, then you can experience this. First step, check vaccum. second step, check ignition (plugs in, wires on, battery/alternator), third step check fuel (filter, lines, pressure) last step check compression.
Old Aug 2, 2007 | 03:13 PM
otter's Avatar
EvoM Administrator
Incorrect valve adjustment can cause idling problems. At one point, I had my valves set so aggressively, that when I had to reset the ECU, the car stalled twice during the learning process. I imagine the same could happen if the lash was too great.
Old Aug 2, 2007 | 03:26 PM
Are you doing that with cam gears or cams?
Old Aug 2, 2007 | 03:32 PM
otter's Avatar
EvoM Administrator
Neither, I had done it with lash.
Old Aug 2, 2007 | 03:55 PM
I what lash is.
Old Aug 2, 2007 | 04:02 PM
otter's Avatar
EvoM Administrator
It's the gap between the rocker and the stem. I'm not going to get into details of what I did, though. Last thing I need is a bunch of people messing with non-OEM specs and ruining their engines.
Old Aug 2, 2007 | 07:24 PM
PR_Mivec's Avatar
^ +1
Old Aug 3, 2007 | 01:53 AM
reTro's Avatar
What year is your car and how many miles do you have on it?
