04-06 Ralliart Engine/Drivetrain (no forced induction)
leaky exhaust?
Old Sep 12, 2007 | 07:35 AM
byc_panty's Avatar
leaky exhaust?
ok so after getting my dp and cat welded in and bolted on...
i find it sounds pretty nice with the magnaflow muffler
but at certain gears/revs... i get a occasional higher pitch raspy sound from underneath... so i took it back to the mechanic that installed it and i coulnt feel any leaks...(with my hands near the welding areas)...
does it mean there might be a tiny leak somwehre? jus sound isnt consistent...
Old Sep 12, 2007 | 11:11 AM
bruce988jl's Avatar
I have a tiny leak when the exhaust is cold... but yea i dont mind it only lasts for like 5 min. I think i'm leaking around my O2 sensor since it was stripped upon installation from the factory. I had one hell of a time getting it out...
Old Sep 14, 2007 | 08:44 PM
hellview's Avatar
i have a wierd... kind-problem with my cb aswell. when i first my car for the first 5 minutes, it feels like.. i dont know... like i got about 20ib/tq total at low rpms. its like real laggy.
when i put it on i didnt reset ecu but then i did it about 3 months later and its not as bad but its still there.
Old Sep 14, 2007 | 09:52 PM
flybyjs130's Avatar
yo view, u need to upgrade ur body pronto, u dont even no the potential u have
Old Sep 14, 2007 | 10:55 PM
bruce988jl's Avatar
I know what you mean by lag. Right now I'm having problems with the catback leaking between the midpipe and the axel back. Since its a clamp style fitment it doesn't seal 100% which kinda sucks sometimes cause it makes a hissing sound when i get on it while the exhaust is still cold. Also I'm noticing some leaks in the welds around the resonator... if water/humidity can get out of it so can water. Gonna take some exhaust sealant goo to it sometime next week.
Old Sep 15, 2007 | 01:33 PM
stitch_sack's Avatar
what rpms do you hear it
Old Sep 15, 2007 | 05:42 PM
migs647's Avatar
I gotta say, for the amount of problems I hear about after upgrading the downpipe / header... it doesn't seem like it's worth it. Does it really make a big difference in performance? Or is it sound that you guys like? I'm almost thinking about keeping stock exhaust and just adding a piggy and intake manifold to my udp and cai.
How does the performance compare to stock?
Old Sep 15, 2007 | 06:32 PM
byc_panty's Avatar
the dp does have improvements..
there is a special Kick when you gun it... but overall you can save money and just customize your stock dp
i ripped open the stock dp heat shield covers and it does look really crimped up..
i dono why they did that
Old Oct 8, 2007 | 10:57 PM
hellview's Avatar
what do u mean??
