Throttle Position Sensor
Very. $600+ (list price is over $800.) However, for some reason the throttle body off the 3.8L V6 Eclipse is only $163, and it's electronically controlled just like ours. I've been told that it bolts up and does work on our car, but being a bigger TB it'd probably require a bit of tuning to install it.
That's what I've been told. It's probably going to have to be one of those things where somebody volunteers to be the test dummy and shares the results with the rest of us. For as cheap as it is, I'm sure there's somebody who would do it. Ideally, whomever does it would be wise to make sure they have a way to port out the IM where it mates to the TB, as well, so everything flows well.
Mitsu told me that it was the TPS, but i def wouldn't pass it by them to tell me the name of a part and it actually be something different. it also was up in the front of the car
ANY MORE INFO ON THE 3.8L V6 Throttle body?!??!
whats the size
does it bolt on to our manifold
does it plug and play at our cars!?!?
thanks im trying to find this info for a few weeks, and nobody helps me!!
whats the size
