04-06 Ralliart Engine/Drivetrain (no forced induction)
Got 5 CEL codes
Old Mar 19, 2009 | 06:52 AM
wake's Avatar
Got 5 CEL codes
I got 5 codes when I plugged my CAN OBD2 car reader yesterday and would like you to help me with that stuff.
P0100: Mass or volume air flow circulation malfunction
P0110: Intake air temp (AT) circuit malfunction
P0115: Engine Coolant Temperature Ciruit Malfunction
P0120: Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P1600: Serial Communication Link Malfunction
My car don't run in limp mode...he's jump taking more gas!!
Does anybody can help me with that?
My car is a 06 RA and here are my mods :
SRI injen with K&N filter
Engine damper
custom downpipe with a high flow cat
RRM axel-back
RRM underdrive pulley
TWM short shifter and shifter bushings
Old Mar 28, 2009 | 09:47 AM
wake's Avatar
Nobody has an idea?
Old Apr 1, 2009 | 07:40 AM
SSP-Ralliart's Avatar
Engine damper
RRM axel-back
There may be a fault in the ECM. Considering all those devices recieve and send out information to the ECM. Maybe even a wire shorted to ground or even a bad ECM ground hard to say. You can find out what each diagnositic procedure is for each code but more then likely they are caused by 1 problem. I may be able to help ya but i also don't know how good your electrical diagnosis is. First i would find out what the diagnosis is for these codes and go from there. If you have any questions feel free to give me a buzz.
Old Apr 1, 2009 | 08:53 AM
wake's Avatar
With what you're saying, I think I'll go to the dealer and see what they think of it!!! It should be on the waranty so I'll see!
