04-06 Ralliart Engine/Drivetrain (no forced induction)
clutch lines...are they interchangeable?
Old May 2, 2010 | 08:36 PM
roblaza's Avatar
just like the topic says... are there any other mitsu's that share the same cluth lines, OR even the same fittings??
the reason i'm asking is i found a site that has stainless clutch lines for 1g and 2g eclipse's for twenty bucks...and if the fittings are the same as on the RA's i thought it'd be a much better buy than the $70 rrm lines...they come in silver, black, red and blue braided lines...
just a thought, does anyone know?
https://www.rtmracing.com/xcart/prod...at=1253&page=1
Old May 2, 2010 | 08:53 PM
otter's Avatar
EvoM Administrator
The upper line is the same as an Evo line. RRM's line is the lower line, which AFAIK, nobody else makes. However, the stock lower line is a hardline, so if you didn't want to buy a braided line to get rid of the restrictor, you could just gut it.
Old May 2, 2010 | 08:58 PM
roblaza's Avatar
gettin rid of the restrictor is my goal... as you can tell when it comes to transmission components i'm a pretty big noob... so long story short, that line i found will not eliminate the restrictor?
Old May 2, 2010 | 10:15 PM
Raikiri's Avatar
check out here. I hear that these guys make pretty good ss brake lines as well =] almost bought some from them since they come with all 6
http://www.techna-fit.com/clutch.html
Old May 3, 2010 | 05:03 AM
roblaza's Avatar
did you buy the clutch line through them?? what one did you order cause it says 02-04 lancer, 02-06 evo, 06 evo 9...
