04-06 Ralliart Engine/Drivetrain (no forced induction)
valve component comparison
Old Dec 8, 2013 | 04:42 PM
mbm19's Avatar
i was doing some research between 4g69, 4g63, and the 4b11t valve components, and i was able to find alot of the measurements for the three heads. first off the 4g69: valve head diameter: intake- 34mm exhaust- 30.5mm valve head margin thickness: intake- 1.0mm exhaust- 1.2mm valve overall height: intake- 111.33mm exhaust- 113.54mm valve stem diameter: 6.0mm valve spring free height: intake- 54.8mm exhaust- 56.1mm valve guide inside diameter: 6.0mm i had to measure the stock 4g69 valve spring outside diameter and i got 7/8 of an inch(22.5mm)
4g63t: valve head diameter: intake- 34mm exhaust- 30.5 valve head margin thickness: intake- 1.0mm exhaust- 1.5mm valve overall height: intake- 109.5 exhaust- 109.7 valve stem diameter: 6.6mm valve spring free height: 47.0mm valve guide inside diameter: 6.6mm valve spring outside diameter: 1.100"(28mm)
4b11t: valve head diameter: intake- 35mm exhaust-29mm valve head margin thickness: intake- 1.022mm exhaust- 1.094mm valve overall height: intake-113.25 exhaust- 105.90mm valve stem diameter: intake-5.47mm exhaust-5.46mm valve spring free height: 51.5mm valve spring outside diameter: .990"(25.146mm)
at the moment i have all the parts for a 4g63 and i will be working with those parts to build my spare head for a future all motor then turbo build! hopefully this helps out anyone trying to build their head!
I put the link down below cause I couldn't copy the pics. I haven't posted anything new on there cause I've been busy with work. But I hope you guys find these info helpful!
http://club4g.org/board/4g-eclipse-g...omparison.html
maperformance
Apr 9, 2018 09:48 AM
senate6268
128
Sep 3, 2015 10:44 PM
maperformance
Feb 11, 2015 03:23 PM
doncarbone
15
Feb 11, 2014 01:18 PM
maperformance
Dec 20, 2010 08:13 PM
