04-06 Ralliart Engine/Drivetrain (no forced induction)
Cam Upgrade
Old Jun 16, 2014 | 02:30 PM
lbwilliams44's Avatar
Cam Upgrade
Ok so after reading around and calling a few people, I can't seem to figure out if we have a cam upgrade available. Talked to Delta Cam and they said it just is not possible. Somebody had also mentioned the RPW cam, but I am told Australian Ralliarts have a different cam profile/setup.
Can I get a clear answer on this? Should note car is staying N/A.
Old Jun 16, 2014 | 04:51 PM
DirtyRalli's Avatar
I have the rpw stage 2 cam.. They do make a few 4g69 cams and a cam gear
Old Jun 16, 2014 | 09:05 PM
No issues? after talking with Delta and reading a rather lengthy thread, they said it simply cannot be done. Saw some pics of the damage the regrind did.
With their stage two did you need to upgrade the springs or any of the internals? Maybe just some valve lash? Got any videos?
Old Jun 17, 2014 | 06:48 AM
DirtyRalli's Avatar
The rpw cams are expensive but a great upgrade, my cars been great so far. They have a few different grinds, stage 2 was the safest, no other valvetrain work needed to be done, just the valve lash and a tune
Old Jun 17, 2014 | 07:36 AM
Awesome, thanks. I just have to figure out which mods I want to do first now
Old Jun 17, 2014 | 07:40 AM
Did you bother with their cam gear?
Old Jun 17, 2014 | 02:48 PM
CrAnSwIcK's Avatar
do cam gears even do anything for a SOHC?...you can't really time the intake and exhaust valves separately...
if they can make cams for 4G63 MIVEC, they should be able to make one for a SOHC head...mind you, apparently even HKS 272 camshaft only gives a 4G63 turbo like 10hp.
Old Jun 17, 2014 | 03:49 PM
DirtyRalli's Avatar
Yeah i bought the cam gear too just so i can have both brand new
Old Jun 17, 2014 | 03:53 PM
DirtyRalli's Avatar
The cam for these cars make good power. Stock these cars are probably 140-145 whp, and after only my exhaust, the cam, and a sri (which most likely didnt add much) my car dynoed 185 whp
Old Jun 18, 2014 | 08:17 AM
Yeah that was what I was trying to figure out, if it would actually do much if anything. I think I will probably skip it.
@ DirtyRalli does it add any cam lob to the car or is it pretty smooth?
Old Jun 18, 2014 | 09:37 AM
DirtyRalli's Avatar
The car idles kind of rough, it sounds good though. Because the idle is so bumpy its causing my cel to come on every 2 monthes about with a random multiple missfire code, it doesnt actually missfire, the cam is just pretty aggressive
Old Jun 18, 2014 | 10:20 AM
CrAnSwIcK's Avatar
how do you know it's not misfiring? if it was the idle causing it, it would happen every time you idle the car...
Old Jun 18, 2014 | 01:04 PM
Yeah, that would be odd if it caused an occasional random misfire code. A little lob is fine with me. My last daily driver had 280/280.
Old Jun 18, 2014 | 06:51 PM
DirtyRalli's Avatar
I reset the code every once in a while and it takes a while for the code to cone back, its not missfiring because iv replaced everything possible and the car runs fine with no sign of missfire
Old Jun 19, 2014 | 08:47 AM
If I went for a more aggressive cam or just wanted to upgrade my springs. Are there any others that swap with ours? Like hopefully the 4G63? I think i still have a set of FFWD Bee-MAD somewhere.
