04-06 Ralliart Engine/Drivetrain (no forced induction)
rotating flywheel clockwise
Old Jul 12, 2014 | 05:20 PM
04rallikid's Avatar
I rotated it backwards 1 to 2 turns. Why? Tightening the flywheel. The rope down the cylinder worked but the first few times I guess there wasnt enough rope. When I went to remove it got stuck and took an hour to remove.
I have been told that rotating the flywheel clockwise can bind up the timing belt and make it skip a tooth. Sounds possible, not sure what the tensioner looks like though.
Old Jul 12, 2014 | 06:45 PM
CrAnSwIcK's Avatar
verify timing, and continue, next time don't turn it backwards
Old Jul 13, 2014 | 09:46 AM
04rallikid's Avatar
Ha ha ok. I guess I will read the timing belt replacement sticky.
Old Aug 1, 2014 | 02:11 PM
04rallikid's Avatar
I should have looked or remembered that the crank pulley has a 1/2 socket hole I could have used. Dang it. Anyone have the exact alldata steps for checking timing. The thread was ok but really only 3 of the posts are helpful.
EvolutionRacing
Jun 1, 2016 07:12 PM
overdrive1
May 15, 2014 09:52 AM
greenytingz
Lancer Engine Tech
Jan 19, 2013 09:50 AM
DormantBeast
Feb 12, 2012 03:25 AM
turbo dragon
Nov 22, 2010 06:40 PM
