04-06 Ralliart Engine/Drivetrain (no forced induction)
05 Ralliart doesn't chirp in second anymore
Old Apr 1, 2015 | 07:41 PM
VMC216007's Avatar
My car use to chirp really loud in second gear ! Now it doesn't chirp at all . My through out bearing has been making noise for a while ! Maybe clutch is starting to slip ? It shifts perfects no problem just doesn't chirp like before ! Trust me I'm pushing it and the weathers been hot and still nothing any ideas ?
Old Apr 1, 2015 | 08:30 PM
CrAnSwIcK's Avatar
hot weather makes your tires softer, maybe it's just gripping better?
tires not chirping is kind of a vague symptom....also hot air is less dense
get a turbocharger, and try getting ANY traction through the entire 2nd gear....lol
Old Apr 1, 2015 | 08:46 PM
VMC216007's Avatar
Lol I see little Hondas chirping hard af in second gear I'm like damn lol my **** don't chirp at all now !!! And trust me I know I'm running 100 shot of nitrous !
Old Apr 2, 2015 | 08:06 AM
Ev0ikon's Avatar
Originally Posted by vmc216007
lol i see little hondas chirping hard af in second gear i'm like damn lol my **** don't chirp at all now !!! And trust me i know i'm running 100 shot of nitrous !
wth?
Old Apr 2, 2015 | 08:42 PM
VMC216007's Avatar
Originally Posted by Ev0ikon
wth?
Wth what ? It's not chirping when I'm not running nitrous because it used to . Lol with nitrous I have no traction . Wth?
Old Apr 2, 2015 | 10:06 PM
CrAnSwIcK's Avatar
is it possible your clutch starting to slip?
Old Apr 3, 2015 | 02:06 AM
VMC216007's Avatar
That's what I'm thinking because my through out bearing been making noise for a couple thousand miles ! Any good clutch kits?
Old Apr 3, 2015 | 10:07 AM
CrAnSwIcK's Avatar
throw out bearing doesn't make your clutch slip..lol
clutch kit depends on your needs...you're running 100 shot...so you probably should have at least a stage 1 clutch.
so ACT HD/SS, or clutchmasters FX-100 or 200
spec apparently makes decent clutches as well...
Old Apr 4, 2015 | 11:08 AM
VMC216007's Avatar
I know it doesn't make it slip but it's a sign that soon clutch might start slipping and yeah I'm going with act stage 3 clutch
Old Apr 4, 2015 | 02:10 PM
xmaster19's Avatar
Things I know that have an impact on chirping ability :
Clutch condition
Tires
Road conditions (temp, dampness, etc.)
Engine/tranny mounts
Suspension
Driver
Condition of crossmember (see below pics)
My guess is your front engine mount is shot, like mine was.
Replace it with a Blox Roller stopper for an Evo8 if it isn't already done. It will also help control clutch chatter (clutch bouncing on the pressure plate) and wheel hop.
My mount was torn almost all the way. Inspect your crossmember just in case.
Old Apr 5, 2015 | 09:54 AM
RalliartN's Avatar
Then run the same Walmart "Douglas Xtra" iron doughnuts as those little tu*ds.
p.s. damn these holiday ad pop-ups are cheesing me off - what is going on with evom now?
Old Apr 5, 2015 | 12:10 PM
CrAnSwIcK's Avatar
hahaha, so true...I'm sure I could find a set of tires that I could chirp in 4th gear...
Old Apr 6, 2015 | 06:37 AM
2006_RA's Avatar
Ad Block Plus to the rescue.
Old Apr 6, 2015 | 09:51 AM
RalliartN's Avatar
Thank yuh, sir. btw, how are things on your end, car-project-wise?
Old Apr 6, 2015 | 10:18 AM
2006_RA's Avatar
^^ going nowhere fast.
I will not revisit till May at the earliest, when the aim will be to:
Split donor engine and gearbox
Replace timing belt and water pump on donor engine
Remove flywheel
Get RA to pass emissions test or whatever they call it this year
Remove engine and gearbox from RA then solicit Cranswick and you to help with replacing the IPS bearing and install LSD
That should take me to the end of June.
