04-06 Ralliart Engine/Drivetrain (no forced induction)
Engine Compartment Exhaust System Heat Shielding
Old Aug 2, 2004 | 01:16 PM
nucleartrainer's Avatar
Question Engine Compartment Exhaust System Heat Shielding
My first post!
Does anyone know of any problems encasing the headers / factory heat shielding in a high temp insulating material? This would significantly reduce the underhood temperatures.
I don't understand why Mitsu would put a thin heatshield with holes on the headers.
2004 Phoenix Red Ralliart
SLO county California
OEM Mesh Grills
Still evaluating the mods
Old Aug 2, 2004 | 01:39 PM
lrh35's Avatar
Even with the holes It lowers the temp. They are there so that air flow will push hot air down and under the car. I used 1200 degree ceramic paint on mine and did a coat of high gloss 500 degree paint over that to make it look better. There where a couple posts on this a while back. do a search. you'll get all the info you need.
Old Aug 2, 2004 | 02:45 PM
Thanks,
I will search. Unfortunately, you have to wait 15 seconds between searches.
