04-06 Ralliart Engine/Drivetrain (no forced induction)
Kartboy Ameoba shifter base bushing question...
Old Aug 3, 2004 | 11:01 AM
sillypuddy's Avatar
Which side is up? the smaller side or the large side is up?
-joe
Old Aug 3, 2004 | 11:55 AM
pocoRA's Avatar
The ones I installed for the shifter housing it was 2 bushings per bolt and the small machined side would face towards the housing so that it fits in their snug, one above, one below. Hope this helps, not sure if your bushings are the same. The smaller side should fit perfectly into the hole where the old rubber bushing was.
Old Aug 3, 2004 | 05:59 PM
AdamRA's Avatar
You should email kartboy, but from what pocora said it seems like the smaller side should fit in there perfect.
Attached Thumbnails Kartboy Ameoba shifter base bushing question...-bushing.jpg
Old Aug 3, 2004 | 06:49 PM
sillypuddy's Avatar
all the other kits use 8 pieces, two for each bolt, one on each side
the kartboy kit has 4 pieces only, so not sure if it goes top or bottom of the shifter
-joe
Old Aug 3, 2004 | 09:14 PM
AdamRA's Avatar
keep us posted on how it goes, I still need to install mine.
Old Aug 4, 2004 | 12:29 AM
pocoRA's Avatar
My guess would be that the bushing goes on the top of the housing with the small side down into the hole the old bushing fit in, that way the bolt will hold the bushing down and the bushing holds the shifter housing in place, if you put it underneath then the bolt would just be holding the bushing down but not the housing.
On a side note, I just installed the bushings for the shifter cable connection under the hood, and it's a pretty sick combination, B&M and bushings, I would recommend it to anyone.
Oh and AdamRA have you joined lancernation.net yet? I see you're in vancouver, we try to get together every so often, you should check it out if you havent already.
Old Aug 4, 2004 | 11:15 AM
mojambo's Avatar
I know for sure they go on the bottom with the small portion facing up. I just installed B&M precision short shifter, and they only have 4 bushings and they go on the bottom against the floor. same with kartboy
Old Aug 4, 2004 | 11:17 AM
pocoRA's Avatar
how does it hold the housing in place? it would seem that the housing would just be resting on top of the bushings? anyways, i installed an 8 piece kit so I'm just guessing at this
Old Aug 4, 2004 | 11:27 AM
sillypuddy's Avatar
hmm.. Dr. Crash sold them to me, so I am going get his opinion on it
-joe
Old Aug 4, 2004 | 03:09 PM
Myszkewicz's Avatar
If it's only 4 pieces, the smaller end would go face down, on top of the shifter base.
With 8 pieces, 4 go under the base, smaller end face up, and 4 pieces go face down on top.
Old Aug 7, 2004 | 08:00 PM
tom@kartboy's Avatar
yes the bushings go from the top down (small end goes into the base)
i've been way swamped at the shop so i havent had a chance to do a install page yet.
if anyone has any questions please email me
Tom
Old Aug 19, 2004 | 04:28 AM
d3wu's Avatar
i had to actually trim the small end of the bushing with a knife to allow it to fit. make sure you check your small end fits fine.
at first i thought mine was fitting fine but the bushing was actually kinda flexing because it was just a little too big.
