UnholyMaggot |
Jul 10, 2016 10:58 AM |
:helpme: Injen CAI, sudden bucking and stalling
Just put the Injen CAI on my 04 Ralliart. I took it for a drive and filled up on gas. As I was leaving I really went hard on it, hit the Limiter (not entirely intentional) and suddenly the car started bucking around 3k, every gear. i let it idle, it has a hard time idling and ends up turning off half the time, i start slowing down to hit speed bump or stop sign and it stalls. i disconnected the second tube and put the filter on as a short ram and in runs a bit better but still does all the same as above. Its dry out so i know i didnt suck any water up, Occasionally it does backfire through the intake. i get the feeling when i redlined i managed to jump time and bend an intake valve im not sure, any thoughts? :helpme::helpme: Everything is stock too, no other performance parts on the car. Plugs were done about 2k miles ago along with the valve cover gasket, i have a delphi MAF/IAT (i have the stock one that might still be good if that might be the issue) and i have been having CEL for p0113 (Intake air temp circuit a too high) but this is the first time the car has done this. ive had a short ram on the car since i bought it (came on the car already) and has ran fine, the IAT code just started about a month or so ago and the MAF/IAT didnt fix it either.
