Firewall Help
Old Oct 9, 2004 | 02:56 PM
jeddi's Avatar
Firewall Help
Hmm I'm in search of a new firewall. I am installing something and need several wires to go thru the firewall. There is one near the brake/tranny fluid area. That one is in use by my amp wire. Any other area I can use please respond asap. Thanks
Old Oct 9, 2004 | 05:00 PM
otter's Avatar
EvoM Administrator
A new firewall?? o.O You mean a new firewall hole? I found a spot to drill beneath where the clutch bottoms out, easy to get to from both inside and outside the car. I've heard there's a rubber grommet on the passenger side, as well, behind the glove box and all that.
Old Oct 10, 2004 | 12:58 PM
jeddi's Avatar
ughhh
I tried to take the capartment box out once but was not successful in doing so. I hate this.
Old Oct 10, 2004 | 05:10 PM
otter's Avatar
EvoM Administrator
Open up the glove box. On the left side, you'll see the point that stops it from opening further. This is a removable tab. You can slide this thing towards you and it snaps out. I'm not quite sure how to describe it without pictures, but when you remove this piece, you can easily get the glove box out.
