hid retro
Old Feb 17, 2005 | 06:41 AM
Alliedcries's Avatar
http://www.hidexpress.com/ I know nothing of this company but they have conversion kits.
I don't know if their product is good or not but they have conversion kits. looks easy and cheap.
Old Feb 17, 2005 | 07:28 AM
zeof's Avatar
i looked into that...but, it's the glare that i am concern about. check this article out http://www.danielsternlighting.com/t...nversions.html
this is the reason why i don't want to spend the money on hid kit. i rather spend my money on something that will not only benefit me as well as my fellow drivers.
Old Feb 17, 2005 | 07:52 AM
pinoynoskillz's Avatar
my cousin actually bought 2 conversion kits from hid express. they are nice and good. well worth the money.
Old Feb 17, 2005 | 07:57 AM
its not hard at all to retro fit. all you gotta do is cut out a circle on the housing so the projector will fit, and glue it on there or some type of caulk, and then thats it.
Old Feb 17, 2005 | 08:45 AM
zeof's Avatar
any recommandation for type of glue to glue the pojector onto the headlight? what kind of projectors do u have? e39? e46? e55? tsx? s2000? what kind of wiring harness did u used and where did u buy it? as for ballasts...what kind? how and where did u mount ur ballasts to?
Old Feb 17, 2005 | 12:24 PM
mojambo's Avatar
SKI,
modern racer is on cardomain. I don't have the link, but its a yellow RA and he;s bulding a turbo if that helps. They are very bright, still yellow in color but VERY noticable
Old Feb 17, 2005 | 12:41 PM
any projectors will do, HID kits usually come witha ballast... as long as its a 9007 type light, then it will be fit for our stock wiring... glue maybe the same caulk they would use on like tail lights so that it doesnt get moisture in.... anything that holds good
you know?
Old Feb 17, 2005 | 12:54 PM
lookslikeanevo's Avatar
^ i think that you are over simplifying it by a lot. most people that do a retro, will also change out the backside, yes you do have to cus a hole, but if you cut that hole then you will now have to use the bulb size that the projector is using not the original bulb size....
Old Feb 17, 2005 | 01:47 PM
ModernRacer's Avatar
Ok every one, i'm here and Yes i have done the conversion, and no they'er not to bad at night.yes they are very bright, but i have installed "glare shields" inside the housing to reduce the glare(my own invention), not to blind on comming traffic,and they work very well at that.Maybe in the futur i may install projector lenses but for now they work fine.If i can can help anyone with this mod please feel free to PM me, mojambo has seen this install he knows my reputation.
http://www.cardomain.com/memberpage/661914
Old Feb 18, 2005 | 08:14 AM
zeof's Avatar
alrite guys...i will be a test rat for this. just ordered my projectors and all the hid stuffs....so, i will keep u posted.
Old Feb 18, 2005 | 08:26 AM
how much did you spend for the projectors and HID stuff in total
Old Feb 18, 2005 | 08:35 AM
zeof's Avatar
projectors (audi 6 OEM single xenon projectors) $120
ballast (philps) + ignitor + 4100k philps bulb $200
wiring harness for 9007 socket $75
be able to see at night.....priceless
Old Feb 18, 2005 | 09:10 AM
speedygarcia's Avatar
I really don't recommend this mod, this is common in Mexico, but the aligment never is perfect, 'cos you have to modify the headlights!!! but is uo to you!
Old Feb 18, 2005 | 09:20 AM
zeof's Avatar
that is part of the risk....but, from what i have read...the aligment is fixable. i will make sure that i measure out every twice and cut only once onto my headlight.
i do want to buy an extra set of headlights..just incase i f#@k up. but, the only place i can get it is through the dealer. so, i am putting my lights at risk, as well as, my stock wiring...but, it is the risk that i am willing to take to be able to see clear as day at night.
Old Mar 2, 2005 | 11:15 PM
SlowRyd's Avatar
Hey Zeof, check out HIDPLANET.com, their forum has a wealth of info about doing the Retro. i am going to do it as soon i have the time and money and workspace. it'll probly be a summer project, but i have a HID kit now and the glare isn't that bad.
