Aluminum Tie Bar
Old Apr 29, 2005 | 07:20 AM
ModernRacer's Avatar
Originally Posted by AlkalineTrio124
??? Quick question... Less stiffness!?!? Isn't the point of a tiebar stiffening up the suspension!?
Your right, what i meant is that the rear suspension will still be able to have very slight movment and still retain the stiffness you need for handleing
Old Apr 29, 2005 | 09:37 AM
jdizzy's Avatar
How heavy is it?.. Is it solid or hollow?... Solid aluminum can be very heavy... what grade of aluminum is it?..
Old Apr 29, 2005 | 10:40 AM
ikeing's Avatar
^^ yes i agree solid aluminum will be really heavy if its not hollowed out. what are rrm's made from ?
Old Apr 29, 2005 | 12:16 PM
The bar is solid, is 1inch in diameter, and weighs less than 1 pound, so it<s very light
Old Apr 29, 2005 | 12:31 PM
Also RRM`s bar is made of hollow steel and weighs more than mine
Old Apr 29, 2005 | 02:24 PM
Rydog's Avatar
so just so i'm clear on where this is going, this is attached underneath on the rear suspension tying the two sides of the 'a-arms' or whatever they're called? is that right?
Old Apr 29, 2005 | 04:11 PM
That's right
Old Apr 29, 2005 | 05:06 PM
BLKRalliArt04's Avatar
Modern, you have made a lot of sweet stuff, why dont you sorta
"mass produce" some stuff, especially that rear thingybobber you made a little over a month or so ago. good stuff
Old Apr 29, 2005 | 05:26 PM
jdizzy's Avatar
that's pretty light... it must be soft aluminum... I'm not trying to cut down your product, just curious
Old Apr 29, 2005 | 06:19 PM
captain150's Avatar
A tiebar stiffens up the frame/suspension mounts, it doesn't do anything to stiffen up the suspension itself.
Old Apr 29, 2005 | 09:52 PM
ev-slo's Avatar
75 canadian is what in american
Old Apr 30, 2005 | 06:24 AM
it's $59.00 U.S. + shipping
