Engine Light??
Old May 19, 2005 | 06:49 PM
RAKenzo's Avatar
Engine Light??
Today I was driving my RA and my engine service light came on... I installed my RRM CAI 2 weeks ago and there was no light up until this point. There was a little rain out today, but I doubt that had anything to do with it, maybe i'm wrong. I have no idea what to do at this point, any suggestions?
Old May 19, 2005 | 06:52 PM
insomniac_evo's Avatar
it might be the rain, mine went on and off, the sensor might detect some moisture, its fine
Old May 19, 2005 | 06:54 PM
Myszkewicz's Avatar
Try resetting your ECU and see if it comes back. If it does, take it in and get the scan tool connected and the code pulled to see what the problem is. By take it in, I mean to someplace that can do this, not necessarily your dealer. Try Autozone first, although I don't know if their scan tool can read our codes.
Old May 19, 2005 | 07:20 PM
RAKenzo's Avatar
Alright thanks for the tips, I'll see if it stays on for the next few days, then I'll check the piping, and then send it to an autoshop. It's probably nothing.
Old May 20, 2005 | 05:36 AM
BLKRalliArt04's Avatar
If it has anything to do with the cai, its more than likely you didnt tighten something down PERFECTLY or didnt install it PERFECTLY. The computer would not recognize a little water in the intake. It what my computer guru guys like to call "user error" I doubt its anything serious though.
Old May 21, 2005 | 07:41 AM
CF-Ninja's Avatar
did u hose clamp your Filter on?? because i didnt think it was nessesary to clamp it on and it ended up popping off on my 1/2 mile test drive.... might wanna take a gander down there
Old May 22, 2005 | 05:11 PM
RAKenzo's Avatar
Yeah i clamped down the filter. Later that day I took out the air sensor and then retightened it. Checked for leaks and if it has moisture in the pipe. Neither of that was was there. I drove it out of the garage and it went off. Weird...
Old May 22, 2005 | 09:44 PM
Ralliart2004's Avatar
There is a possibility you could've broken your MAF sensor, but your car probably wouldn't run very good without a reading or a drastically altered reading.
