Is there a way to adjust the sensitivity of the gas pedal?
You can loosen your throttle cable, that'll increase the dead zone in the pedal, but it affects everything, not just first. Run a search for tightening the throttle cable...the reverse should also be true.
I recommend wearing smaller shoes and training yourself to be more gentle. The Ralliart, and other models can be jumpy, but you can learn to overcome this with a more gentle approach.
Thanks guys, I'll look into loosening the throttle cable.
Smaller shoes is not always an option, especially when going to work or going out.
I have a really worn pair of bball shoes with very worn (thin) soles that I prefer to wear when driving, but I can't wear those all the time.
Get some Onitsuka Tiger's... They are probably the sweetest driving shoes. Thin sole, grippy enough, comes in colors that match any Ralliart Color. They are also stylish about anywhere you go. Oh yah... They are JDM also
Originally Posted by tuffguy
Sometimes it's a little too sensitive in 1st gear, making the car a little jumpy. Is there a way to decrease the sensitivity?
I'd also recommend the WORKS clutchline. It stiffens up the clutch pedal with will probably help you with you acceleration issue since you will have more control over the clutch.
