Broken Tailight
Old Jul 29, 2005 | 04:02 AM
LeftysRule22's Avatar
Broken Tailight
hey guys, i was driving home yesterday and noticed that my right tail light isnt working...the blinker, reverse, and brake lights work but the regular red light when you turn your lights on doesnt....i only have 5000 miles on the car...but i have a subwoofer in the trunk, might have rattled it a bit, im not sure...anyone with a subwoofer/s had the same problem? it seems strange that a almost new bulb should die so fast.
thanks for any input
Old Jul 29, 2005 | 04:40 AM
diameters's Avatar
what kind of bulb did you get? maybe the bulb wasnt good in the first place and just died out... it shouldnt of happened but if you ahve a receipt, take it back and get a new one. also make sure your wires are tightly secured...
Old Jul 29, 2005 | 06:20 PM
fifty1fifty's Avatar
Bulbs burn out, buy a new one! They cost a couple bucks....or get LED ones and never have 'em burn out again!
Old Jul 30, 2005 | 09:53 AM
BLKRalliArt04's Avatar
I dont think an LED bulb would function correctly in our taillights, or if it did it wouldnt produce a bright enough light because it is more of a focused beam compared to a basic bulb that produces light over a wider range.
Old Jul 30, 2005 | 10:02 AM
Hellacious's Avatar
I thought the 04+ Lancers had LED tails?
Old Jul 30, 2005 | 10:06 AM
Myszkewicz's Avatar
I was just looking at LED bulbs yesterday, they make some that have LEDs pointed out, and then more arranged radially around. You'd get light going in all directions.
I'm thinking about getting them, because the f**king security guards where I work keep slamming my trunk and breaking the filament in my taillight bulbs.
Since our blinkers are (as far as I can tell) controlled by an ECU, they should still flash at the right speed.
Old Aug 2, 2005 | 03:14 PM
x3racing's Avatar
ever thought about gettin after market taillights? would that be a cheaper solution?
Old Aug 2, 2005 | 06:49 PM
twisty1251's Avatar
check your fuse. i think its a 7.5a fuse under the hood.
Old Aug 2, 2005 | 06:53 PM
They dont make aftermarket tails for 04 and up Lancers. I highly doubt it is your fuse, its just a burnt out bulb. If it still doesnt work after you put the new one in, then yeah check the fuse.
Old Aug 3, 2005 | 03:21 PM
well it was the fuse....i didnt think it would be the fuse but i checked anyway and sure enough...im hopein there not a short or something so it wont keep happinin
Old Aug 3, 2005 | 03:32 PM
I actually got pulled over today for a burnt out brake light. (the cop let me go) I went to check the fuse just for shi*s and giggles and sure enough it was blown......weird.
Old Aug 7, 2005 | 06:38 PM
CF-Ninja's Avatar
does that fuse replace with one of the extras located behind that little glove box under the stearing wheel?
