timing
Old Aug 16, 2005 | 02:33 PM
candycain's Avatar
Registered User
timing
ok guys, got another question for you. i want to advance my timing a little when i go to the track. but i don't know how to do it on this engine. i used to be able to do it on my sohc vtec honda i had a couple years back. but it was really easy. this is WAY different. what do i need to do? so far it looks like the only way is to use an adjustable cam gear but they don't make any for our cars right?
brad
Old Aug 16, 2005 | 03:00 PM
Myszkewicz's Avatar
The problem with the adjustable cam gear is that it changes the ingition timing by changing the valve timing. Not exactly the best route.
You'd have to slot the bolt holes on the cam angle sensor in order to have adjustable ignition timing without playing with your valves.
Old Aug 16, 2005 | 06:22 PM
reimundo's Avatar
the 4g64 cam gear works. the 2000 to 2005 eclipse rs gs has this motor!
Old Aug 16, 2005 | 11:46 PM
candycain's Avatar
Registered User
sweet thanks guys!
Old Aug 22, 2005 | 03:19 AM
candycain's Avatar
Registered User
ok, got another question. where are the timing marks on the engine???? please respond soon!!! thanks.
Old Aug 22, 2005 | 06:14 AM
PR_Mivec's Avatar
at the crank
