Help: Easy question Tire Pressure
Old Aug 24, 2005 | 02:58 PM
EvosLilBro's Avatar
Whats the Tire Pressure supposed to be for our stock tires? I suck at reading the sides of tires my front tires are low and i want to check my back ones as well
Old Aug 24, 2005 | 03:00 PM
PR_Mivec's Avatar
i use them @ 35 psi
Old Aug 24, 2005 | 03:03 PM
EvosLilBro's Avatar
is that what the manual suggests? I don't have a users manual and i can't find a pdf online or anythin, I'm just lookin for the basic pressure, no racing or drag pressures. if its 35 then thats cool, leavin for the gas station in a few minutes
Old Aug 24, 2005 | 03:21 PM
Joe Spingler's Avatar
It's on the driver's door jamb. 32 PSI for all four. Never go by the sidewall, that indicates max pressure for that tire, and not necessarily the pressure for your application.
Old Aug 24, 2005 | 03:35 PM
KODAM's Avatar
I thought it was 31 on all four. I read on here once somebody's dealer lowered theirs to 26 but I forget why. Lower pressure gives better grip at launch, but life is shortened. I get good overall performance at 31 and thats with no passengers 80% the time. Always check "cold" and try not to drive too far to fill them up as driving more than a mile will increase the pressure a little.
Old Aug 24, 2005 | 05:01 PM
WoRkZ's Avatar
Post
I use 34 in the front and 33 in the back... that's what gives me the best grip and most even wear. Results may vary. Anyway, I don't use the stock tires...
Depending on the way you drive the car (IE: no fast cornering or hard acceleration), you might be better with 32 in the front and 31 in the back. If you give even a bit of importance to wear, always go with a pound more in the front, even two if you're really agressive with your driving. This will help save the outer part of the thread, thus wearing the thread a bit more like the rears (which do not slide as much, even in thight corners).
A good way to know if you've got the right pressure for your type of tire and your way of driving is to start at 30 pounds and then gradually increase up to 35 if you hear the tires squealing when going around fast corners...
That's just my personnal method though, others may recommend alternate ways to determine your optimum pressure.
Old Aug 24, 2005 | 07:06 PM
Myszkewicz's Avatar
I run 45 in the front and 75 in the rear.
Oh, wait. That's my truck.
34-35 front and 33 rear in my car.
Old Aug 24, 2005 | 07:27 PM
WoRkZ's Avatar
Talking
Glad to see I'm not the only one who figured out that pressures do not necessarily have to be the same from front to rear...
Old Aug 24, 2005 | 07:53 PM
captain150's Avatar
The tires probably say something like 38 or 40PSI, which would suck. The driver door jam says 32PSI I believe, so 33-34 would be fine.
Old Aug 24, 2005 | 10:22 PM
AdamRA's Avatar
32 front Thats what I use.
35 rear
Old Aug 24, 2005 | 10:51 PM
reimundo's Avatar
sh*t ! i'm at 40psi all around.
Old Aug 24, 2005 | 11:12 PM
Myszkewicz's Avatar
Well, for a while I had them all the same, 34 or 35. Then after all the stiffening up of the rear suspension, it was getting a little squirrely in some turns, so I dropped the rears a bit, and it seemed to help. I don't want to drop it any more, because I do a LOT of highway driving, so I want less rolling resistance.
Old Aug 25, 2005 | 08:37 AM
otter's Avatar
EvoM Administrator
35psi front and 32psi rear for daily driving.
38 front and 35 rear for autoX
Old Aug 25, 2005 | 10:19 AM
WoRkZ's Avatar
Exclamation
How's the wear on the center of the thread??? One would assume it's quite higher than on the sides... especially on the rear tires.
Old Aug 25, 2005 | 10:20 AM
WoRkZ's Avatar
Question
Interesting. What kind of tires? Do you swap for autoX?
