Question about wiring
Old Sep 6, 2005 | 01:53 PM
Ralli04Art's Avatar
i got a pioneer AVIC N1, and i need to know what harness and wires i need to hook it up. i stil have the stock infinty single cd player in the ra right now. anybody know?
Old Sep 6, 2005 | 05:12 PM
otter's Avatar
EvoM Administrator
Just the normal Mitsu wiring adapter for Lancers. Available at your local sound shop or through Crutchfield.
http://www.crutchfield.com/S-OQMqIva...sp?i=120707001
I should clarify, you don't have the S&S system, right? If you do have it, that's a different problem. For that you'd need an adapter from www.soundgate.com
Old Sep 6, 2005 | 05:34 PM
WoRkZ's Avatar
Post
Well, it says in his info he has a SS RA...
AdamRA's Avatar
It says he has a SS ralliart I guess he does sun and sound.
There is a place in Texas that has the MITAH cable which is the same as the soundgate.
www.installer.com
Old Sep 6, 2005 | 05:40 PM
WoRkZ's Avatar
Post
There's already a couple of threads about this... but here's what the adapter looks like:
http://www.discountcarstereo.com/detail.aspx?ID=434
Old Sep 6, 2005 | 09:16 PM
DangerousDan's Avatar
I went the cheap way and tested all the wires that come out of the harness to find what was what. of course I was just being lazy not wanting to run wires to all the speakers since Mitsu has kindly done so already. I put my amps under the seats and ran bigger wire for the subs, but thats it. you can't even tell I have a system unless you know it's there
Old Sep 7, 2005 | 12:31 PM
Ralli04Art's Avatar
ok so do i need the wiring harness AND the adapter cuz i have the infinity, or just the inifity adapter and thats it?
Old Sep 7, 2005 | 01:18 PM
WoRkZ's Avatar
Post
If you want to hook your aftermarket HU to your Infinity amp, you just get the adapter. You might need a low voltage trigger too... I'm not sure how the amp would be turned on if you didn't get that. But some of the guys on here did the same swap you're doing, they'd know for sure...
Old Sep 7, 2005 | 01:22 PM
kmcconn9's Avatar
ok there are several choices that you have.
If you want to keep the stock infinity amp and speakers, you will need an adapter to keep the amp working. Soundgate makes one, the mitsamp. Thats all you will need.
If you do not want to keep the stock infinity sound system then you can use a general met 807001 harness. You will either have to run wires to all of the speakers. Or tap on to the inputs from the speakers at the factory amp which is under the drivers side front seat....
hope this helps...
Old Sep 7, 2005 | 01:26 PM
kmcconn9's Avatar
I would reccomend using the stock amp with the soundgate mitsamp adapter. It will simply plug in and your done...
