Idle adjustment...
Old Oct 29, 2005 | 10:27 PM
Starlite Demon's Avatar
Idle adjustment...
I did a search on this topic and found nothing... does anyone here know how to adjust the idle? becuz my idle is soooo low its not even funny!
Old Oct 29, 2005 | 10:32 PM
Ralli04Art's Avatar
how low can you go?
mine is high
like 850-1000. doesnt get much lower than that
im at 600 or so jsut right above the 500 so i wanna know how to adjust real soon
Old Oct 29, 2005 | 10:39 PM
Ralliart2004's Avatar
Mine idles at around 600 as well, didn't figure it to be a problem since it's done that since the day I bought it with 30 miles on it.
Old Oct 29, 2005 | 10:41 PM
my idle used to be at like 700 or 800 now its like 500-600 and just sitting there my lights dim a lil. i want to raise my idle back to where it used to be
Old Oct 29, 2005 | 10:44 PM
so anyone here know how?
Old Oct 29, 2005 | 10:52 PM
Myszkewicz's Avatar
Try cleaning your throttle body. From what I can tell, there is no adjustment, it's all handled by the ECU. I'll keep looking, though.
Old Oct 29, 2005 | 10:58 PM
yes plz any info would be helpful cuz i am lost and i would really like to adjust it
Old Oct 30, 2005 | 12:00 AM
justinhazard's Avatar
mine is 600 also, no probs though
Old Oct 30, 2005 | 12:30 AM
Myszkewicz's Avatar
Well, this is what it says:
INSPECTION PROCEDURE 10: Idle Speed Is Low (Improper Idle Speed).
COMMENT
• In cases such as the above, the cause is probably that the intake air volume during idle is too small.
TROUBLESHOOTING HINTS (The most likely causes for this case: )
• Malfunction of the electronic control throttle valve system.
• Malfunction of the throttle body.
As I said before, try cleaning the throttle body. Over time, some gunk will build up in there, and the passage for idle air isn't very big. Come to think of it, I should probably at least pop off my intake tube and have a look at mine. I haven't cleaned mine in 48,000 miles. My idle's a tiny bit lower than I seem to remember it being when new.
Old Oct 30, 2005 | 05:03 AM
Dade County's Avatar
what do you want to clean it with?
Old Oct 30, 2005 | 08:00 AM
otter's Avatar
EvoM Administrator
550-600 idle is normal. 700-800 is normal when the A/C compressor is running. There's a sticker under the hood that states this.
Old Oct 30, 2005 | 08:01 AM
otter's Avatar
EvoM Administrator
Look for the aeresol can labeled something along the lines of Intake/Throttle body cleaner. The stuff is pretty easy to use, just follow the instructions on the can closely.
Old Oct 30, 2005 | 08:47 AM
Thanks
Old Oct 30, 2005 | 01:52 PM
PR_Mivec's Avatar
actually i have a digital tach and my idle when the car has no a/c is 700 steady and 800 steady with it on....
