Engine prob...?
Old Jan 4, 2006 | 03:13 PM
ralliart2k4's Avatar
I had that happen to me once or twice but only for a moment and then it cleared itself up. I've always attributed it to a spot of bad gas or something...though I always use name brand gas (shell, texaco...yadda yadda.)
Old Jan 4, 2006 | 10:59 PM
myfakeevo's Avatar
i think you should check your air inlet housing, maybe you have esomething loose, those stock boxes are junk. and even aftermarket intakes, rattle apart because of the torque that the ralliart puts out, make sure all of the air parts are secure
Old Jan 5, 2006 | 02:49 AM
can04rali's Avatar
holy shmokes!!!! look at all this input!! There is so much that it " could " be. Just hope that its nothing to serious for you
Old Jan 5, 2006 | 04:41 PM
Ralli04Art's Avatar
ok dumb question what is "wot"
Old Jan 5, 2006 | 04:44 PM
mitsutech005's Avatar
wide open throttle
Old Jan 17, 2006 | 02:34 AM
reTro's Avatar
-UPDATE-
I seem to have fixed my problem!!!? It's been two weeks now, and no stuttering. Not exactly sure which of this worked, but here is what I did.
I took apart my intake and re-installed it, making sure everything was nice and tight, including the MAF sensor. Unhooked piggyback, and re-connected, making sure all connections had good contact. Re-set ECU. Ditched my Denso spark plugs, and installed NGK's.
I've punched it (WOT) in hot weather, cold, and when the car had been running a few minutes, and a few hours. The problem has seemed to disappear?!
I'm kinda suspecting something was up with the plugs, but time will tell. Thanks for everyone's input!
