hi i was thinking of getting the fuel management system on my car and would like....
Old Jun 25, 2006 | 01:28 PM
ralliartm's Avatar
hi
i was thinking of getting the fuel management system on my car by Apexi and would like to know if it is worth it and what changes would it create on my car
performance
currently i have the Injen cold air intake
let me know
thanks
Old Jun 25, 2006 | 01:53 PM
lanzerralliart's Avatar
EvoM Super Moderator
with just a cai i don't think that it would be to useful, now don't get me wrong a fuel management system is good and useful but with the limited number of mods you have i would consider...underdrive pulley , full exhaust system ,rear swaybar and/or tiebar before you start messin with the fuel and even with those mods an upgraded fuel system isn't needed........but i do some searches if i were you so you understand what your getting into...
Old Jun 26, 2006 | 10:51 PM
chowetime's Avatar
at the moment I have only got a set of headers, full exhaust setup and a K&N pod filter.... this actually helped with the current stock fuel maps because instead of the factory setup were the car was running rich (which is very common for all Mitsubishi cars) it has now leaned up the fuel/air mix I know it may seem a bit strange but because we have more air entering and exiting the car it has in fact evened out the ratios a bit better there will still be room there to get more gains out of a air/fuel management setup bu tit is not worth it at the moment till more mods are done. So the same goes for you - save your money get more mods then get a air fuel system.. will also save you time and money on each mod as you will have to get it tuned each time a mod is added
