"performance" which spark plug is BEST for the ralliart
Old Aug 10, 2006 | 12:03 AM
sndm's Avatar
hi im getting my 04 ralliart tuned and i want to change the stock tune up parts. i was wondering what is the best auto transmission fluid and spark plugs. my friends suggested me mobil 1 for engine oil. What ever tune up products you think is best on performance please post. i've done alot of searching and they all sound the same to me thank you for your time
Old Aug 10, 2006 | 06:14 AM
Ralliart50's Avatar
I would stay with the stock plugs because you can't get too much better than them. They are iridium plugs which are very good plugs. For engine oil, go with some 5W - 20 Royal Puple. You should also check into the Royal Purple ATF for your tranny. I've heard great things about that but haven't had a chance to run it in my auto tranny yet. I'm due for a tranny flush and that's what I'm going to put in it.
wikid4.6's Avatar
Royal purple tranny fluid and for plugs your local advance,napa etc. will have a broad selection
Old Aug 10, 2006 | 06:25 AM
otter's Avatar
EvoM Administrator
Stock spark plugs are about the best you can get. They're NGK Iridiums. Expensive to replace, but they last about 90k miles.
Old Aug 10, 2006 | 09:03 AM
sndm's Avatar
http://www.ngksparkplugs.com/product...420&country=US
NGK iridium ix plugs
do these plugs work?
are they better?
currently mine are stock
i wanna try new stuff but wanna make sure if its safe,good first
Old Aug 10, 2006 | 11:01 AM
Eclipse2Lancer's Avatar
No need to really swap the stock plugs before you have a crapload of miles. Do you want to just change them to change them? If so....don't. No need to, the stock iridiums (believe it or not) are really the best ones.
Old Aug 10, 2006 | 12:01 PM
reTro's Avatar
What everyone else has already said is true. OEM plugs are the best you are going to get for our cars because of who makes them.
There are only two plugs that are compatible with our cars:
Denso IKH20
NGK 3656 (OEM: #LZFR6AI)
They will both run you about $10-12 a plug becaue they are iridium. Don't go to the dealer because they will charge $100 for all 4!!! I've tried both and the Denso's started misfiring after about 10K miles, so I went back to the NGK's and have never had a problem.
Old Aug 10, 2006 | 02:23 PM
sndm's Avatar
thank you very very much that was very helpful. now i know not to get it from the dealers
Old Aug 14, 2006 | 11:41 AM
Ryan_VRX06's Avatar
I don't know how it goes for every county, but in Aust. the 06 at least, comes wit NGK plugs stock
Old Aug 14, 2006 | 01:19 PM
The US versions come with NGK's too. At least my 2004 did.
Old Aug 14, 2006 | 02:12 PM
ralliart 04's Avatar
if you race your car alot or just get on it alot how soon do you guys think we should replace them, cause my car is 2 and a half years old now and i do get on it alot so i would think that the plugs would need to be changed more offten then the average driver?
and im more then willing to pay 40-60 bucks for a new set of ngk's but not if they arnt needed yet.
Old Aug 14, 2006 | 06:36 PM
otter's Avatar
EvoM Administrator
If you're not sure you can visually inspect them, however, they should be just fine for 90k miles, no matter what your driving style.
Old Aug 15, 2006 | 01:59 PM
Punkskalar's Avatar
you can visually inspect them... Get a good gap guage (feeler guages work well) and visually look at the electrode and porcelane (sp) and measure the gap... Should be listed under the hood, though i have never checked on this partular vehicle...
Old Aug 15, 2006 | 02:09 PM
good ideas,thanks
Old Aug 16, 2006 | 06:15 AM
I posted specs for plugs in the stickied Newbie post:
OEM Spark plugs part number - LZFR6AI (NGK Iridiums)
Gap - 0.028-0.031 inch; 0.7-0.8mm
Torque to 18 ft/lbs; 25 Nm
