i need to know where.....
Old Aug 27, 2006 | 11:26 PM
Ralli04Art's Avatar
the fuel pressure regulator vaccum hose is on our cars............
Old Aug 27, 2006 | 11:53 PM
DangerousDan's Avatar
Fuel tank image key
REMOVAL STEPS
1.FUEL FILLER HOSE, FUEL LEVELING HOSE, FUEL TANK VAPOR HOSE CONNECTION <FUEL FILLER NECK SIDE>
2.FUEL MAIN PIPE
3.WHEEL SPEED SENSOR
◄A►4.FUEL TANK INSTALLATION NUTS AND BOLTS
◄A►5.HARNESS CONNECTOR CONNECTION
◄A►6.FUEL WIRING HARNESS CONNECTION
◄A►•FUEL TANK ASSEMBLY
►A◄7.FUEL HIGH-PRESSURE HOSE
8.FUEL FILLER NECK BREATHER HOSE
9.FUEL VAPOR HOSE
10.FUEL FILLER HOSE
11.FUEL SHUT-OFF VALVE
12.O-RING
13.FUEL TANK VAPOR HOSE
14.FUEL TANK CHECK VALVE
15.FUEL TANK VAPOR PIPE
16.FUEL TANK ROLLOVER VALVE ASSEMBLY
17.PACKING
18.FUEL TANK LEVELING VALVE ASSEMBLY
19.PACKING
20.FUEL LEVEL SENSOR
21.PACKING
22.FUEL TANK DIFFERENTIAL PRESSURE SENSOR
23.O-RING
24.PLATE
25.PACKING
26.FUEL PUMP BRACKET PLATE
27.FUEL PUMP MODULE
28.PACKING
29.FUEL TANK
REMOVAL STEPS
30.FUEL FILLER HOSE, FUEL LEVELING HOSE, FUEL TANK VAPOR HOSE CONNECTION <FUEL FILLER NECK SIDE>
31.FUEL FILLER NECK PROTECTOR
32.FUEL VAPOR PURGE HOSE B
33.FUEL VAPOR HOSE
34.FUEL TANK FILLER CAP
35.FUEL FILLER NECK
36.PACKING
37.FUEL VAPOR HOSE
38.FUEL FILLER NECK VALVE
engine view key
1.THROTTLE BODY
►C◄2.THROTTLE BODY GASKET
3.VACUUM PIPE AND HOSE
4.SOLENOID VALVE
5.SOLENOID VALVE BRACKET
6.INJECTOR AND FUEL RAIL
7.INSULATOR
8.INSULATOR
►B◄9.INJECTOR
10.O-RING
11.FUEL RAIL
12.EXHAUST GAS RECIRCULATION VALVE
►A◄13.EXHAUST GAS RECIRCULATION GASKET
Maybe this will help you. I am not exactly sure what you need though.
Attached Thumbnails i need to know where.....-m2281304_00907.png   i need to know where.....-m2281304_00908.png   i need to know where.....-m2281704_00150.png   i need to know where.....-m2281704_00175.png   i need to know where.....-m2281104_00259.png
Old Aug 28, 2006 | 03:44 AM
matute's Avatar
Last time i cheked our cars didn't have FPR!!!
Old Aug 28, 2006 | 04:00 AM
Myszkewicz's Avatar
They do, it's just built into the fuel pump assembly inside the tank. There's no vacuum line running to it.
