Prohector issue
Old Nov 1, 2006 | 03:56 PM
ralliart329's Avatar
Angry Projector issue
I got a set of projectors from partstrain.com and the passenger hibeam came not working which i was not going to take my front bumper off to take out the headlight and get the to replace it.
Tonight i turn the low beams on and the passenger side doesnt come on for about 5min. and it now happens every time i start the car....!!!
before i call them and try to get it replaced i was hoping someone may have an idea.
Old Nov 1, 2006 | 04:43 PM
CF-Ninja's Avatar
bad wiring harness? did u wire everything up right? was it a direct plug in?
Old Nov 1, 2006 | 04:46 PM
direct plugin. i tried a few bulbs in the highbeam with no luck and left it. now the low beam really pisses me off. i gues ill have to look at it better on sat. when ill be home with the sun still up...
at this point im thinking if its not just a wire loose then i gues ill have it replaced.
Old Nov 1, 2006 | 06:30 PM
I went out and looked with a flash light and on of the wires for the low beam came off. a little solder (sp?) and good as new. unfortunately this wasnt the case with the high beam but ill play with that more this weekend if i get bored.
thanks for the suggestion CF-ninja!! you got me wondering to the point i just got up and fixed it.
