Interior lighting question for 04 RA owners
I noticed that my ashtray, glove box, and the circle surrounding my lighter don't light up at night. I think my 05 RA had lights for all three. Does this sound like a blown fuse? or is this what all 04 models have?
Thanks. Is this something simple that I can fix myself? Or do I need to spend hours at the dealer? I might simply wait until something else goes wrong, but I'd like to do it myself if it's a simple fix.
Well, I'd start with fuses. Does your cig lighter work? You might want to check the connections to those two lamps, but you would need to remove the center console which is not too bad of a job.
cig lighter works, but the ring around it doesn't light up. the ashtray also doesn't light up when I open it.
Did you by any chance take out the center console and forget to plug it back in? I know there's a light for those, not sure if they're connected to the cig. lighter though...
-Lee
-Lee
I never took out the center console, although doesn't mean the prior owner never did. Im' the second owner.
Working on it.
EDIT: The ashtray and lighter ring lights get their power from a different circuit than the lighter itself. The lights you're trying to fix get power from the taillight fuse. They do share some connectors and ground with the lighter, though. The connectors they don't share with the lighter are up inside the dash, I don't think they'd be unplugged.
Best bet would be to take out the center console and see what you can find under there. Could be burned out/missing bulbs, or unplugged wiring, or cut wires. Who knows what the previous owner did to it.
if you pull your ashtray out you should see a the bulb toward the bottom near the gear shifter. i think. mine have been out for a while, i'm to lazy to change bulbs, but i can def. see the burnt bulb.
Must be common, I noticed mine don't light up now either, I think it happened over the summer.
cameronh88
Sep 21, 2011 09:12 PM
ralliart 04 21
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 5, 2006 08:45 AM
moncef
15
May 12, 2005 07:57 PM
