odd sound from clutch pedal?
Old Feb 14, 2007 | 07:26 PM
akujiki87's Avatar
ok this is odd, my car has started to make like a rubbing sound from the clutch pedal when its SLOWLY released, like starting from first. it will do it for awhile then go away. i had a guy tell me it was a clutch pedal bushing so i ordered it and have not put it on yet(NO TIME) but could this be it? anyone know if it may be something else? thanks!
Old Feb 14, 2007 | 09:46 PM
Myszkewicz's Avatar
Mine does that when starting in second gear, as when driving in snow. It's done it since new, and has never been a problem. I never hear it in 1st, only in 2nd when I'm letting the clutch out slowly to get moving from a stop.
I'm not too worried about mine.
Old Feb 14, 2007 | 11:55 PM
akujiki87's Avatar
i can feel friction in mine. can u? its seems odd. maybe im paranoid...lol
Old Feb 15, 2007 | 03:44 AM
Myszkewicz's Avatar
No, mine doesn't feel any different, just makes a little noise once in a while.
Old Feb 15, 2007 | 06:49 AM
Eclipse2Lancer's Avatar
mine makes noise and I can feel the "notchiness" when I let the pedal out slow. It's the pedal bushings. Not a big deal (can be lubed up).......and it is a common issue with Mitsu clutch pedals (same thing happened on my Eclipse). Happens more often when it is cold.
Old Feb 15, 2007 | 11:12 PM
akujiki87's Avatar
i was really thinkin it was the coldness. its been oddly chillie here in southern cali thanks guys!
Old Feb 16, 2007 | 05:58 PM
AdamRA's Avatar
Mine squeaks sometimes normally winter only. Again this car is not for winter or cold climates it seems to hate it.
Old Feb 17, 2007 | 09:39 PM
ikeing's Avatar
try some oil on the pedal hinges might help
Old Feb 17, 2007 | 10:32 PM
AdamRA's Avatar
Yes it will help but it comes back ina few months
Was looking at your sig you ever use Victaulic fittings?
Old Feb 17, 2007 | 10:48 PM
ikeing's Avatar
then reoil every few months victaulic couplings are a brand name like a skidoo or kleenx but yes?iv installed over 20 000 of them.
Old Feb 17, 2007 | 10:53 PM
AdamRA's Avatar
I work for them... 20,000
Old Feb 17, 2007 | 11:06 PM
Thegreydevil219's Avatar
yeah mine squeaks, and no matter how much lube you put on it it still squeaks
easy solution.....turn up the radio i guess
Old Feb 18, 2007 | 08:46 AM
otter's Avatar
EvoM Administrator
Add mine to the list. Just haven't bothered to get under there and grease them.
Old Feb 19, 2007 | 09:22 PM
superalf574's Avatar
i can feel the friction and mine makes noises my ra only has 3k on it
