Front Break Line
Old Mar 24, 2007 | 06:03 PM
willRalliart's Avatar
Front Break Line
How Do I remove the rubber section of the front brake line. I got the part off the caliper, but I can't figure out how to get it off the bracket where it goes from metal line to rubber hose. I backed out the screw/nut thing - from the top portion of the bracket
TIA
Old Mar 25, 2007 | 09:20 AM
otter's Avatar
EvoM Administrator
There's a spring clip you need to pull out. It has a lip on the end so you can use a set of needlenose to wiggle it out.
Old Mar 25, 2007 | 09:49 AM
so the top part is what actually pulls out?
Old Mar 25, 2007 | 11:10 AM
otter's Avatar
EvoM Administrator
Yup.
Old Mar 26, 2007 | 09:38 AM
Thanks for the quick response otter, one more question -
is the breakline the same on the evo 8 and 9's as on the ralliart? I am wanting to know, in short, if I can just buy stainless braided lines for the evo 8 or 9 and they will just bolt up -
Thanks
Old Mar 26, 2007 | 01:35 PM
otter's Avatar
EvoM Administrator
Nope, you need one specifically for the Ralliart.
