Problem in my HID light
Old Mar 26, 2007 | 04:00 PM
abcarino's Avatar
hi everyone , i just bought a new hid plus h4 high & low beam in my lancer glx , the prob is that sometimes when i turn on my hid only one bulb works the left one or the right one , so i went to the guy that i bought from he changed all the wires and connections with new ones and still the problem occurs , any help
Old Mar 26, 2007 | 08:43 PM
chengstar's Avatar
you might need a relay to your battery...thats all i can think of i you've changed all your wiring
Old Mar 26, 2007 | 08:48 PM
superalf574's Avatar
whats a glx sport
Old Mar 26, 2007 | 10:43 PM
Black Rally's Avatar
u need to disable the daylights
Old Mar 27, 2007 | 08:37 AM
Ralliart Girl's Avatar
I have that same problem. I thought maybe it was the bulb manufacturer and it wasn't a good fit for Lancers.
DRL you say...
Old Apr 13, 2007 | 09:54 AM
gjgfrombigd's Avatar
Mine do that too. I don't think it's anything to worry about. It's just a voltage situation between the headlight switch and the balasts.
Mine do something else though...after the first 2-3 minutes of operation (it seems like after the bulbs reach full operating temperature), each of my headlights individually have a short blink. After the blink, they operate for hours without doing it again. Turn them off and back on again, 2-3 mintues later, they blink once, each, again.
Wierd
Old Apr 13, 2007 | 10:09 AM
DRL you say...
yes, DRL
Old Apr 13, 2007 | 08:00 PM
AdamRA's Avatar
If you don't turn off the DRL you will eventually lose the ballast.
Old Apr 16, 2007 | 08:11 AM
What affect does the DRL have on the lights working periodically? I not get!
Old Apr 16, 2007 | 09:43 AM
teknix's Avatar
Registered User
drls run on a lower voltage than what HIDs are required to run. so if you don't disable it, you'll get flickering and eventually blow a ballast.
