need help
Old Jun 21, 2007 | 11:07 AM
winnnnnn2's Avatar
need help
shredded the screw on the air sensor on intake. how do i take the screws out?
Old Jun 21, 2007 | 11:31 AM
Cj98's Avatar
neddle nose pliers or use a drill with a bit and drill through the screws so all you would have to do it just pull out the sensor shouldnt be to hard
Old Jun 21, 2007 | 12:14 PM
drewbad's Avatar
I lost one of mine, so I bought an M5 bolt. Did the trick. Good luck man!! The MAF is touchy, so make certain you don't have leaks when you're complete dude.
Old Jun 21, 2007 | 08:58 PM
hellview's Avatar
+1
Old Jun 22, 2007 | 12:49 AM
Cow town racer's Avatar
Same thing happened to me a couple years back, its an easy fix, go to Canadian Tire and buy the mastercraft stipped screw removal kit. It has two drill bits in it that will take the bolt out in a second.
Old Jun 22, 2007 | 04:21 AM
Realistic's Avatar
yeah, if the threads leak. Go to a plumbing shop and buy teflon tape.
Tape up the threads except the first two (screwing in)
that should help seal it
