Exhaust Help!!
Old Jun 30, 2007 | 04:14 PM
  #31
MITVRX's Avatar
Hey orlando, yeah I'll give them a ring (it's Sunday by the way). But they have a cell phone number so I'll give that a call.
Tell me what you all want to know so I can have questions ready for this vendor.
1. How much?
2. Cost shipping to the states.
3. Cost of a group buy etc.
Ask all the questions here so I know what to ask! hehe
Old Jun 30, 2007 | 04:22 PM
  #32
migueralliart's Avatar
1. How much?
1- HOW MUCH SHIPPED TO THE US zip code 98026
2- Is this supposed to be installed between the header and cat? or after cat?
I am very interested in this device, it seems we can finally control backpressure and get advantage of it .....
Old Jun 30, 2007 | 04:30 PM
  #33
MITVRX's Avatar
Bad news, the cell number is "disconnected".
I'll try find another way to contact them.
Old Jun 30, 2007 | 04:35 PM
  #34
Those *******!!!
Old Jun 30, 2007 | 04:55 PM
  #35
KreepaEvoX's Avatar
Bollocks!!!
Old Jun 30, 2007 | 05:30 PM
  #36
MITVRX's Avatar
I've since searched the website and found no contacts.
Take a look at this Migue!
http://autospeed.drive.com.au/cms/article.html?&A=0893
Old Jun 30, 2007 | 06:03 PM
  #37
yeah I read all their articles on exhaust systems and that web site has great info ...
NOte, after analizing here at work this system is pretty easy to manufacture, even the controller is easy to make Here is my INTRO :
Ok so they basically use a machined Throttle Body .... they modify the accelerator cable part and install a circle plate instead... for the control they use a vacuum actuator similar to the ones used on the N/A cruise control cars... and for the controller you will need a few parts that are cheap also such as pressure switches and vacuum solenoids (similar to those used on A/C systems)
Old Jul 2, 2007 | 07:27 AM
  #38
matute's Avatar
Ok i know you guys went trough this but i am running with the stock "header" 2.5 Custom DP with HF Cat, resonator and 2.5 Borla Muffler and sounds just a little bit louder than stock. The cat is removable and i have the test pipe for track nights. And regarding the cops in PR they tried to give my brother a ticket with stock exhaust and after a serious talk with the officer i convinced him that it was a stock system. The intention of the law is that you should not remove the muffler or modify it (striping the internal parts) in order to make noise. Any other exhaust system is legal, the problem is that the cops are so DUMB that they dont know or don't give a $h1% and you have to go to court and fight the ticket. I've been pulled over 3 times for tints and have yet to be fined for the exhaust. (knock on wood)
Old Jul 2, 2007 | 07:53 AM
  #39
I really dont know why they are such a morons and always try to give you tickets for exhaust even thou you may have CAT + resonator + muffler..
So you are telling me as long as you have those three things they shouldn't give you a exhaust ticket?
Old Jul 3, 2007 | 07:25 AM
  #40
matute's Avatar
Yup, if you have all the exhaust components in your car they shouldn't give you the ticket. If they don't have anything better to do, they will, but tell them that you are going to court, and that if they don't present themself you are going to present an Administrative copliant ( querella administrativa) against him for labeling you and the car. (remember this is in PR only. I've done it a couple of times and has worked. Good luck!!!
Old Jul 3, 2007 | 02:26 PM
  #41
rdc's Avatar
rdc
To add to this, the law also states that (obviously) removing the Cat IS illegal, this without any relation to noise levels produced by the car, so in other words, just put a HF Cat, and you should be fine with the exhaust you put on as long as its not a straight pipe all the way to the back . Oooooorrr if somehow you could make the car a very silent one w/o the Cat....but I'm pro-nature so stick with the Cat
Old Jul 3, 2007 | 02:34 PM
  #42
So for instance if I have a HF cat + resonator + N1 style muffler I should be fine ?
Old Jul 3, 2007 | 06:56 PM
  #43
matute's Avatar
you should...
Old Jul 4, 2007 | 07:12 AM
  #44
rdc's Avatar
rdc
Yeah, it should make you legal, but again, if its loud, you will catch the popo's attention. You will just have to make your way through or as we say, hacerte de las tuyas .
OT who wants spanish lessons with us??
Old Jul 4, 2007 | 09:45 AM
  #45
$MIVEC$'s Avatar
Again the law states this:
Artículo 14.15- Sistema amortiguador de sonido y aceleramiento del motor
Con relación a sistemas amortiguadores de sonido, se seguirán las siguientes normas:
Todo vehículo de motor que transite por las vías públicas deberá estar equipado con el sistema amortiguador de sonido, el cual deberá estar en buenas condiciones de funcionamiento. Será ilegal usar en el sistema amortiguador de sonido válvulas de escape o cualquier otro dispositivo o aditamento con el propósito de producir ruido. Será ilegal el aceleramiento innecesario del motor o el producir ruido con el mismo en zona urbana.
Por "sistema amortiguador de sonido" se entenderá cualquier dispositivo o artefacto, usado para reducir el sonido producido por la emisión de gases de un motor de combustión interna.
It does not state what level is categorized as unnecesary noise neither it says you have to have OEM muffler(you are allowed to put any muffler you want under legal conditions). all you need is CAT+resonator+muffler.
cops or judge cant say you cant have another muffler because you have a right to replace parts with non OEM ones. All tickets will be becuase of noise regardless because they wont fine you for the muffler...They will fine you because they infer you make noise because you have a "shiny" muffler
matute cual es el borla que pusite el S-type o Turbo....
