Problem after 10 min
If you moved the TPS while changing the cable, theres strike 1, you cant move that part without trouble.
BTW, the TPS is that plastic thingy the acceletaror cable goes to, and lets the throttle motor move when you put your foot on the gas
bring it to the dealer. We can't tell you what your car's problems are without proper details.
Your car isn't starting. This post has been covered for a good amount of time as far as being a "emergency help" post which people tend to reply to, and no avail. There's only so much magic we can work up without codes. I think you might have f'ed up the throttle cable install somehow. Playing with the Throttle Position Sensor is a touchy part.
Was the accelerator cable all you've done? Have you put a CAI on it at all lately? Did you remove the MAF when you messed with the accelerator cable? Sounds like your MAF is bad or loose...
