HID and UD pulley
Old Oct 19, 2007 | 07:07 AM
OttRalliart05's Avatar
HID and UD pulley
Does anyone have a UD pulley and a HID conversion kit??? if so any issues with it??? if this post has been made before I apologize in advance.....
Old Oct 19, 2007 | 08:28 AM
Cow town racer's Avatar
This post has been made alot before. I have the udp and have had no problems with it as of yet. Others have reported squealing from the new belt, however, this is usually solved by putting a new belt in. The udp is an excellent mod and you will feel a difference instantly, I highly reccomend it!
Old Oct 19, 2007 | 08:54 AM
Cj98's Avatar
yup I just put mine on a couple weeks ago and its sqeeking already very nice mod though
Old Oct 19, 2007 | 10:25 AM
BABYEVO1's Avatar
does anybody have the udp with a sound system in their car?? sorry not tryin to steal this
Old Oct 19, 2007 | 11:14 AM
blkralli04's Avatar
if your talking about problems with the udp not giving enough power for the HIDs, you should be fine, bc the hids take more power to get started, but use less the a normal bulb once they are on
Old Oct 19, 2007 | 11:18 AM
Punkskalar's Avatar
If the pulley squeeks a bit, spray some belt conditioner on it.... I did that to mine, and have never heard a squeek out of it since....
Old Oct 19, 2007 | 04:43 PM
I run my udp with large alpine system and the system doesnt make any difference at all
Old Oct 21, 2007 | 12:27 PM
BABYEVO1's Avatar
this might sound dumb but doesnt the UDP not give u enough power to push the subs its just what i have heard i think its wrong but that y i havent gotten the UDP yet
Old Oct 21, 2007 | 01:08 PM
qlitv's Avatar
I don't thinks it really matters, it doesn't do anything it happens in every car if you hit the gas the lights gets brighter at least it happens to me and to some of friends that have the UDP installed with HID and sound system.
Old Oct 21, 2007 | 11:06 PM
egk-69's Avatar
HID = check
RRM UDP = check
Sound system = check
RRM make your car voltage at Idle lower that stock, and lower than it should be, but theres no major problems with that, maybe the sound system won't have the same POWER at idle (I havent notice any changes)
HID- No problem at all, HID even turn on with the DRL, and DRL its 1/2 Voltage.
If you dont have HIDs you will notice the lights dimmer at IDLE thats all.
actually my WideBand reads V. and my car goes to 11.x V. at Idle , which it's lower than it supposed.
