What is this?!
Old Jan 5, 2009 | 06:53 PM
  #31
Beardly P's Avatar
Hail to the Beard
Originally Posted by RalliDew
^^ why do you put a clear cover on the Flux Cap if it says to shield eyes from light??
bc it's goooooooooood
Old Jan 5, 2009 | 07:36 PM
  #32
Cj98's Avatar
the center console is held on by screws and clips, its easy
Old Jan 7, 2009 | 10:20 AM
  #33
Lancer7's Avatar
If that switch doesn't do anything and you want it to do something rather than sitting there or leaving a hole, I wired a switch in my car to disable the ABS for fun driving.
Just a suggestion
Old Jan 7, 2009 | 11:34 AM
  #34
Spooky_Neo's Avatar
Just a suggestion
I actually have a switch sitting doing nothing too in my car. That's not a bad idea, but is it safe ? And how do you turn the ABS off ?
edit : I found out that removing the fuse will take out the ABS, but the idea of the switch is nice. Did you wire the ABS fuse with the switch ?
Old Jan 7, 2009 | 12:43 PM
  #35
Lancer7's Avatar
PM'd back and forth a few times
I guess I should make a how-to since I've had several ask me about it over the years. I won't do it till it gets warmer though.
Old Jan 7, 2009 | 06:05 PM
  #36
MoBralliart's Avatar
Just a suggestion
that spot looks like you might accidentally hit it with your leg from time to time
Old Jan 8, 2009 | 06:28 AM
  #37
Lancer7's Avatar
Good point! I hadn't thought of that. That could turn out real bad.
Old Jan 19, 2009 | 09:13 PM
  #38
Beardly P's Avatar
Hail to the Beard
well, i figured out that the switch belongs to the low and high beams on accident! my lights wouldnt turn on the other night, and after replacing some fuses, cursing the gods, driving to the dealership, and eating at sonic; i saw the switch had been turned off! So i turned it on and realized it controlled the beams when i saw them come back on in the reflective Sonic glass door! Thank god for Sonic! Thank you for all of your comments and suggestions!
Old Jan 20, 2009 | 02:16 PM
  #39
Lancer7's Avatar
Why the hell would someone do that? I'd have that changed back to the factory headlight controls.
Old Jan 20, 2009 | 06:13 PM
  #40
Beardly P's Avatar
Hail to the Beard
haha i know right? why!? the factory headlights are still set, but i have another switch to turn them off! haha
Old Jan 20, 2009 | 07:07 PM
  #41
Spooky_Neo's Avatar
*oh no crap, a cop !
** switching to "silent mode"
Old Jan 20, 2009 | 07:33 PM
  #42
Beardly P's Avatar
Hail to the Beard
harharhar
Old Jan 24, 2009 | 12:15 PM
  #43
Ozrally06's Avatar
See if your day time running light are on during the day when the switch is on it might just be so that the light wouldn't be on during the day but also check if your brake light work
Old Jan 25, 2009 | 10:33 AM
  #44
Beardly P's Avatar
Hail to the Beard
oh yea the brake lights work. I've got it all figured out now!
its just sooo wierd!
Old Jan 29, 2009 | 03:56 PM
  #45
BiCiRA's Avatar
maybe that switch lets you put high beams + fog lights all together... remember that when you turn on your high beams your foglights turn off.... could be it!
