power locks help!!
Old Aug 16, 2009 | 08:47 AM
greger's Avatar
power locks help!!
power locks on my 04 ra are a messed up was wondering if there was a cheep fix or is an new lock system my only hope
Old Aug 16, 2009 | 09:34 AM
Thomar's Avatar
more info required. messed up? what do you mean...
Old Aug 17, 2009 | 02:33 AM
greger's Avatar
the driver side and the pasengerside rear are not working
Old Aug 17, 2009 | 07:57 AM
otter's Avatar
EvoM Administrator
You really need to post more details. What specifically is it doing/not doing, etc.
Old Aug 17, 2009 | 02:16 PM
Thomar's Avatar
so just the rear doors?
Old Aug 17, 2009 | 03:15 PM
Christoforo's Avatar
It's like pulling teeth with this guy
Old Aug 18, 2009 | 02:45 AM
greger's Avatar
sry ok the front driversid dore lock and the rear pasenger side dore locks are at falt. the dores uont lock or unlock with the swiches on the dors nor with the key fob. thay do lock manuly and the other 2 locks are normal.
Old Aug 18, 2009 | 07:20 AM
I have this problem with just my drivers side door lock, I believe the solenoid is either broken or stuck and needs to be lubricated.
I have yet to take my door apart and investigate though. Sorry I couldn't be of much help :\
Old Aug 18, 2009 | 06:42 PM
Thomar's Avatar
greger, how old are you?
No offense, but the typo's are unbearable.
So the drivers door lock doesnt lock/unlock with the remote, and neither does the rear passenger side.
I wonder if it's an electrical issue. Maybe take the door panels off and inspect all moving components, lubricate everything a bit.
Old Aug 19, 2009 | 07:35 PM
greger's Avatar
you will have to excuse my spelling. i just cant spell
i checked all the electronics what should i lubricate and what tipe of lube should i use
