Helpwith MAF cleaning
Old Dec 30, 2009 | 02:33 PM
$MIVEC$'s Avatar
First off...yes I searched. Went to the autopart and asked for MAF cleaner and they got me CRC maf cleaner. I took the time to check the back of the can to see what it actually shoots when it sprays and it said DO NOT use on karman-vortex mafs, turbo supras, mitsubihsis or lexus. Checked on a DSM forum and they many ppl use it, did a search here and many people use it and when I checked the Lexus board all the people who use this fried their maf's since KV does not use the hotwire to work.
Use it or not?
Old Dec 30, 2009 | 02:43 PM
lanzerralliart's Avatar
EvoM Super Moderator
If it's not broken don't fix it ..... My 82 cents
ralliart610's Avatar
i just used it 2 weeks ago. no problems at all.
Old Dec 30, 2009 | 04:12 PM
Thomar's Avatar
i donno... the 'DO NOT use on ...mitsubishi...' seems pretty definitive to me
Old Dec 30, 2009 | 04:21 PM
Originally Posted by otter
stick with the maf cleaner, it'll do the best job without you having to touch the filament. It's cheap, will only cost you $4-5.
if otter says you can use it i think its safe to use. lol. i know i searched after i seen that but seeing how many other people used it with no problems i tried it. and i have no problems from it.
Old Feb 3, 2010 | 05:24 AM
dondon's Avatar
Do our cars have a karman-vortex MAF? If not, what type of MAF is in the Evo?
Old Feb 3, 2010 | 05:26 AM
wasabisnooter's Avatar
So if u cant use this to clean it, what would u use?
Old Feb 3, 2010 | 07:21 AM
TIBOevo's Avatar
ive used maf cleaner before. i cant remember the brand but, everything seems fine. my 2 cents.
Old Feb 3, 2010 | 07:25 AM
otter's Avatar
EvoM Administrator
Well, but if the can says don't use on Mitsubishi, then there's probably a good reason. Companies don't shrink their customer bases without good reason.
Old Feb 3, 2010 | 02:38 PM
the stuff i used is CRC mas air flow cleaner. it says something on the back about not to use on mitsubishi or toyota. i used it a few times and never had any problems with it. im sure other people on here have used it to.
Old Feb 3, 2010 | 06:18 PM
car852's Avatar
i can second the C&C. had used it a few times. still on my first can though haha. i never read the back of the can until i saw this thread. woops.
but yeah. no problems. and my maf is cleean.
Old Sep 2, 2010 | 09:20 AM
jlaznlover's Avatar
Use it or not?
did you end up cleaning the maf sensor with the crc maf cleaner? from my research, evo's do run a karman vortex sensor. the instructions specifically state DO NOT use on karman vortex sensors.
is there any other way to clean the sensor without using this product?
Old Sep 2, 2010 | 09:29 AM
Locdizzel's Avatar
i've used it as well a coupe time with no problems
Old Sep 7, 2010 | 09:36 AM
linste's Avatar
Is the CRC confirmed ok to use? it seems that there is a mix but not body that used and it caused problems because of it. will this be ok for the maf on the X?
Old Sep 7, 2010 | 09:44 AM
4whlbst's Avatar
I'm a Toyota tech and at work we've always used a cleaner from crc called electronics cleaner. It has pics of electrical connectors on a red can. I've used that on the toyotas at work as well as my 1g and 2g I used to own and my evo 8 I still have. If your nervous about the maf cleaner saying not to be used on Mitsubishi then I would avoid it and look for the electronics cleaner.
