Radiator leaking
Old Jan 4, 2010 | 03:57 PM
blkralli04's Avatar
Exclamation Radiator leaking
Ok well found out my radiator is leaking from the upper gasket where the plastic tank meets the aluminum radiator, so i need a new one. I dont really want to go with plastic again, i wanted an all aluminum. Problem im having is i cant find any for our car, my question is would a radiator from a 2.0 lancer es, or oz fit? I know it may be a dumb question but i have to get this ordered tonight so i get a new one in asap.
Old Jan 4, 2010 | 04:41 PM
car852's Avatar
why wouldnt you order one from a ralliart?
or even the one for the evo will fit.
just sayin.
Old Jan 4, 2010 | 04:44 PM
Thomar's Avatar
Right here from mitsubishiparts.net.
Old Jan 4, 2010 | 05:03 PM
blkralli04's Avatar
like i was saying i dont want the oem or any that have plastic tanks, that is where mine has failed and id rather go with an all aluminum if possible, also the oem is like $450, i found some cheaper that fit lancer 2.0 L L4.
Old Jan 4, 2010 | 08:26 PM
RalliDew's Avatar
pending on your plans you could jsut go with a civic aluminum short radiator... those are like maby 120 shiped.
Old Jan 5, 2010 | 03:33 PM
otter's Avatar
EvoM Administrator
Evo rad should fit. I would double check, though.
Old Jan 5, 2010 | 04:14 PM
ralliart610's Avatar
i have an all aluminum evo radiator. its thicker but it fits. both fans mount back on.
Old Jan 5, 2010 | 07:23 PM
lsalex's Avatar
yea evo radiator fits the ralliart ...
Old Jan 8, 2010 | 03:18 PM
blkralli04's Avatar
Someone in my family jumped the gun and order one for me without consulting, needless to say it dosent fit, now im gonna take my time and find the right one, i found a few for the evo 8 that look the same, they are 2 row so i assume they will be thicker, but my concern is if the tank size is the same, and will the pins that hold it in be the same. Id rather not have to do any customization to get it to work, if itll drop in then thats the route im going to take
Old Jan 8, 2010 | 05:16 PM
yea it will fit. the only thing i did was make a bracket for one of the fans. the bolts on top were off just a little bit. i also had to use a grinder to grind away a little bit of the metal on the other fan so it didnt hit the alternator. ill take pics tomorrow. it was one from ebay but it works perfect and everything else lined up.
Go_Lancer_Go
Nov 30, 2014 05:40 AM
Viegasjuice
Jan 9, 2014 11:29 PM
Brigganator
Apr 16, 2013 08:19 PM
polish_pounder
Apr 10, 2013 10:19 AM
mauisurf2003
Lancer Engine Tech
14
Feb 12, 2008 08:29 AM
