upper rad hose
Old Mar 31, 2010 | 09:20 PM
roblaza's Avatar
upper rad hose
what size? i need an adapter for a water temp sender and i need to know what size to order
thanks
Old Apr 26, 2010 | 02:27 PM
jack1526's Avatar
I'd imagine 3/4... I may be wrong... your best bet is to remove the hose just to be more accurate, just be prepared for the coolant coming out.....GL
Old Apr 26, 2010 | 05:19 PM
Thomar's Avatar
doubt its 3/4.. its probably in centimeters. not sure of the actual diameter tho.
Old Apr 26, 2010 | 06:48 PM
lanzerralliart's Avatar
EvoM Super Moderator
3/4 sounds to small you should checkout the evo section as the size is the same im sure and there's more peeps doing this to their cars
